Salta al contenuto principale
Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide
Ilyasah Muhammad
Ilyasah Muhammad e 2 altri collaboratori
Ultimo aggiornamento il March 18, 2025
2 - 5 minuti
Facile
Introduzione
Vai al passo 1
The reader will learn how to replace the back panel/touch screen of the Nikon Coolpix S800c. This may be necessary due to body damage or an improperly working screen that may be defective or cracked screen.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: passo 1, immagine 1 di 2 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: passo 1, immagine 2 di 2
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: passo 2, immagine 1 di 2 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: passo 2, immagine 2 di 2
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
    This doesn’t work!!! I have two S800C cameras, and #1 there are FIVE SCREWS instead of four; one is on the lens side of the case. But once those five screws are out, the LCD will still not separate from the main body. Something in the vicinity of the shutter button is holding the two together. Both cameras are the same in that respect, and because I fear damaging *both* the body and the screen if I try to force it, I’m stuck tight wishing someone could clue me in as to what perhaps simple thing is left out of these instructions.
    The same issue exists with every single guide in this series—the camera WON’T COME APART with the steps shown.
    Brian Capouch - Replica
    The same happened to me. I can't open it because one corner is stuck to the camera near the hdmi port.
    Oliver Gayner - Replica
    There's a screw that is hidden on the top corner. It's under the gray trim that surrounds the buttons. Trim has little tabs, and glue.
    renzomv - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Baylor, Team S2-G6, Johnson Spring 2018 Membro di Baylor, Team S2-G6, Johnson Spring 2018
BU-JOHNSON-S18S2G6
3 Membri
10 Guide realizzate
1Commento della guida
Many steps missing!! There are TWO more screws than the guide tells you about. Plus there’s no mention that after you finally get the camera split, you can’t just tug it apart—the motherboard is attached to the LCD. This guide is about worse than none at all!!
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 21
Tutti i Tempi: 521
