Nikon Coolpix S4100 LCD Screen Replacement
Introduzione
Vai al passo 1If your screen breaks or is no longer responsive to touch, then you will need to replace it. The LCD screen itself has two wires attached that will need to be separated from the motherboard, and reinstalled with the new part.
Cosa ti serve
Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
There are 2 on each side, and 4 on the bottom.
Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Using precision tweezers, gently remove the ribbon cable running from LCD to the bottom side of the motherboard.
1Commento della guida
Quick question would this be similar to replacing the screen for the Nikon Coolpix S4300? I couldn't find anything to fix that specific camera.
