Salta al contenuto principale
Nikon Coolpix S3100 Camera LCD Screen Replacement
Jorge
Jorge e 2 altri collaboratori
Ultimo aggiornamento il 23 lug 2020
10 minuti
Moderato
Introduzione
Vai al passo 1
When you are in a situation whether your LCD screen is malfunctioning, this guide will assist you to find the problem.
Cosa ti serve
Strumenti
  1. Nikon Coolpix S3100 Camera LCD Screen Replacement, Nikon Coolpix S3100 disassembly: passo 1, immagine 1 di 3 Nikon Coolpix S3100 Camera LCD Screen Replacement, Nikon Coolpix S3100 disassembly: passo 1, immagine 2 di 3 Nikon Coolpix S3100 Camera LCD Screen Replacement, Nikon Coolpix S3100 disassembly: passo 1, immagine 3 di 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera LCD Screen Replacement: passo 2, immagine 1 di 2 Nikon Coolpix S3100 Camera LCD Screen Replacement: passo 2, immagine 2 di 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera LCD Screen Replacement: passo 3, immagine 1 di 2 Nikon Coolpix S3100 Camera LCD Screen Replacement: passo 3, immagine 2 di 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera LCD Screen Replacement, LCD Screen: passo 4, immagine 1 di 1
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera LCD Screen Replacement: passo 5, immagine 1 di 1
    • Gently pull the orange board to the right.
  6. Nikon Coolpix S3100 Camera LCD Screen Replacement: passo 6, immagine 1 di 1
    • Lift screen up holding both corners.
  7. Nikon Coolpix S3100 Camera LCD Screen Replacement: passo 7, immagine 1 di 1
    • Gently pull to the left to release from ZIF connector.
Conclusione
Altre 3 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Jorge
Membro da: 03/11/15
1.170 Reputazione
7 Guide realizzate
4Commenti sulla guida
No mention of getting an electric shock while removing the case.Bit of a tingle anyway.I held the camera in a plastic bag after that.
Sindento 1 - Replica
This will probably not be replied to, but is there any reliable way to discharge the flash capacitor? Got shocked once, but I thought it was already discharged lol.
Anirban Bhattacharyya - Replica
Connect a 1k ohm resister between the black and red wire from the capacitor. Give it a few moments to discharge through the resistor. Don't discharge the capacitor without a resistor as you run a good chance of destroying the electronics. Wear your latex gloves too.
gary.grant - Replica
Easy to follow
Janet Miles - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 56
Tutti i Tempi: 2,838
