Salta al contenuto principale
Nikon Coolpix L840 LCD Screen Replacement
Abraham Lozano
Abraham Lozano e 4 altri collaboratori
Ultimo aggiornamento il 4 lug 2020
2 - 5 minuti
Moderato
Introduzione
Vai al passo 1
This guide outlines the steps required to replace the LCD screen. Some parts can be delicate, so care is required when handling this replacement.
Cosa ti serve
Strumenti
  1. Nikon Coolpix L840 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Extend the screen by grasping the screen and pulling it out.
  2. Nikon Coolpix L840 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Unscrew the four black, 4mm Phillip #000 screws on the corners of the back case of the screen.
    • Unscrew the two black, 2mm Phillips #000 screws on the case of the hinge. (The hinge connects the screen to the body of the camera.)
  3. Nikon Coolpix L840 LCD Screen Replacement: passo 3, immagine 1 di 2 Nikon Coolpix L840 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Remove the top-half case of the hinge by lifting it off.
    • Remove the bottom-half case of the hinge by lifting it off.
  4. Nikon Coolpix L840 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Pry the back case off of the screen with a metal spludger by slipping the spludger in between the front and back halves of the screen's case and wiggling the spludger forwards and backwards.
  5. Nikon Coolpix L840 LCD Screen Replacement: passo 5, immagine 1 di 1
    • The front cover comes off easily once the back cover is removed in Step 4.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 1-11, Maness Spring 2016 Membro di Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Membri
10 Guide realizzate
9Commenti sulla guida
Where would you suggest I buy a replacement screen?
leinbergerc - Replica
Yours must be different than mine,. mine required a separation of a sticky piece from around the screen and then getting it back on the new one in almost perfect alignment as you find out when you start putting it back together. I used a prying tool a very small Phillips screwdriver and a very small torx tool, all of which came in the kit I ordered from easyworldwidetrading (Hong Kong) (ebay) for $64.99 no. 302013683286, but make sure yours is the same Camera, good Luck
Michael Crawford - Replica
PS: Be very careful, the piece's are cheap plastic and will break... Now I gotta find the outside piece... ugh
My LCD screen shows what I am taking a picture of but when I hit the picture viewer button the screen goes black. So do I need to replace the LCD screen or do you think it would be something else?
Megan Norman - Replica
My screen is showing a grainy pic especially red I have tried all I can think off. It goes when I turn color right down but leaves screen looking black and white. I know there’s an easy fix but can’t seem to find it. Any help pls
Harris Nnadi - Replica
I haven't seen you unplug the ribbon cable and replace the slide play, you stopped in the middle of the repair, what's the point?
lothar4460 - Replica
My dog ate the screen. Do I absolutely need it, or can I remove it and just use the camera for video without the screen? I have a new Nikon for pictures, so don’t necessarily want to invest in this, but it is great for video clips while I take stills. Any suggestions would be appreciated!
Michelle - Replica
How can I find a replacement part for the screen case bc my l840 display frame is broken on all 4 screws and I need a new one asap bc I love photography taking pics of cute hummingbirds and amazing cars and trucks. But yea I tried everything I could to try and find one at like Ebay Walmart best buy target and none can help me fix it
Daniel Larsen - Replica
Hello. I need the front edge plastic cover. The front part of the screen case.
Where can I buy it?
Josep Maria Solé Lladó - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 4,652
