Salta al contenuto principale
Nikon Coolpix L830 LCD Monitor Replacement
Blake Johnson
Blake Johnson e 3 altri collaboratori
Ultimo aggiornamento il 3 lug 2020
20 minuti
Facile
Introduzione
Vai al passo 1
If the LCD monitor on your Nikon Coolpix L830 is corrupted or completely blank, replacement is necessary. Following these steps will allow you to replace the broken screen with a new one to allow complete monitor functionality to return.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nikon Coolpix L830 LCD Monitor Replacement, LCD Monitor: passo 1, immagine 1 di 1
    • Use a Phillips head P000 screwdriver to remove the four 3.0 mm Phillips screws on the back of the monitor.
  2. Nikon Coolpix L830 LCD Monitor Replacement: passo 2, immagine 1 di 1
    • Use a Phillips head P000 screwdriver to remove the two 3.0 mm Phillips screws on the hinge cover.
  3. Nikon Coolpix L830 LCD Monitor Replacement: passo 3, immagine 1 di 2 Nikon Coolpix L830 LCD Monitor Replacement: passo 3, immagine 2 di 2
    • Remove the top hinge cover.
    • The top hinge cover contains screw holes.
    • Remove the bottom hinge cover.
    • The bottom hinge cover contains no screw holes.
  4. Nikon Coolpix L830 LCD Monitor Replacement: passo 4, immagine 1 di 1
    • Remove the back cover of the LCD monitor with your hands or a plastic opening tool.
    • The cover will slide down the hinge, but it will not be completely removed.
  5. Nikon Coolpix L830 LCD Monitor Replacement: passo 5, immagine 1 di 2 Nikon Coolpix L830 LCD Monitor Replacement: passo 5, immagine 2 di 2
    • Use your thumb to gently pull the small flex ribbon wire connector from its socket.
    • Use your thumb to gently pull the wide flex ribbon wire connector from its socket.
  6. Nikon Coolpix L830 LCD Monitor Replacement: passo 6, immagine 1 di 1
    • Use a plastic opening tool to remove the front cover of the LCD monitor, allowing the monitor to be completely be released.
  7. Nikon Coolpix L830 LCD Monitor Replacement: passo 7, immagine 1 di 1
    • Gently remove the old, damaged LCD monitor.
Conclusione
Baylor, Team 4-4, Williams Fall 2016 Membro di Baylor, Team 4-4, Williams Fall 2016
BU-WILLIAMS-F16S4G4
3 Membri
10 Guide realizzate
2Commenti sulla guida
I cant remove two of the screws. Help
jo Hogan - Replica
Très bien pour démonter , mais pour remonter les nappes, notamment la moins large, je n'arrive pas à l'insérer !
Avez vous une technique à me proposer ?
Michel Cassel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,805
