Salta al contenuto principale
Nikon Coolpix L820 Device Ports Replacement
Marc
Marc e un altro collaboratore
Ultimo aggiornamento il January 20, 2025
Nessuna stima
Moderato
Necessarie Immagini Migliori
Pallini!
Dettagli Mancanti
Introduzione
Vai al passo 1
The device ports on a digital camera can be prone to damage that may render them nonfunctional. This guide will lead you through the necessary steps to replace damaged device ports.
Cosa ti serve
Strumenti
  1. Nikon Coolpix L820 Device Ports Replacement, Settings Buttons: passo 1, immagine 1 di 3 Nikon Coolpix L820 Device Ports Replacement, Settings Buttons: passo 1, immagine 2 di 3 Nikon Coolpix L820 Device Ports Replacement, Settings Buttons: passo 1, immagine 3 di 3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are 10 screws around the casing. 3 are located on the left side of the camera, 6 are located on the bottom near the product label, and 1 is located on the right side of the camera.
  2. Nikon Coolpix L820 Device Ports Replacement: passo 2, immagine 1 di 2 Nikon Coolpix L820 Device Ports Replacement: passo 2, immagine 2 di 2
    • Next, remove the screw held on top of the camera above the Nikon logo.
    • Moving to the bottom of the camera, open the empty battery slot, and locate the 4 screws in the compartment. Begin removing the 4 screws located within.
  3. Nikon Coolpix L820 Device Ports Replacement: passo 3, immagine 1 di 3 Nikon Coolpix L820 Device Ports Replacement: passo 3, immagine 2 di 3 Nikon Coolpix L820 Device Ports Replacement: passo 3, immagine 3 di 3
    • Using the spudger, begin prying the case from the device, carefully separating the rear housing from the camera assembly. Once the rear housing is separated, the camera's physical buttons will be accessible for replacement.
    • Be sure to only apply pressure to the casing panels, not internal electronics. Doing so can damage the internal components of the camera.
  4. Nikon Coolpix L820 Device Ports Replacement, LCD screen: passo 4, immagine 1 di 3 Nikon Coolpix L820 Device Ports Replacement, LCD screen: passo 4, immagine 2 di 3 Nikon Coolpix L820 Device Ports Replacement, LCD screen: passo 4, immagine 3 di 3
    • Remove the front casing around the LCD screen from the camera.
    • Avoid putting pressure or moving the exposed wires. This can damage them and cause lasting issue to the camera.
  5. Nikon Coolpix L820 Device Ports Replacement: passo 5, immagine 1 di 3 Nikon Coolpix L820 Device Ports Replacement: passo 5, immagine 2 di 3 Nikon Coolpix L820 Device Ports Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Using the tweezers shown in the materials list, lift the hinges connecting the two ribbon wires to the camera. The wires will unlatch from the device.
  6. Nikon Coolpix L820 Device Ports Replacement: passo 6, immagine 1 di 2 Nikon Coolpix L820 Device Ports Replacement: passo 6, immagine 2 di 2
    • Once the ribbon wires are disconnected, remove the LCD screen from the camera.
    • Safely store the LCD for reinstallation.
  7. Nikon Coolpix L820 Device Ports Replacement, Device Ports: passo 7, immagine 1 di 1
    • Begin by removing these five screws
  8. Nikon Coolpix L820 Device Ports Replacement: passo 8, immagine 1 di 1
    • From there, the panel covering the motherboard can be removed.
  9. Nikon Coolpix L820 Device Ports Replacement: passo 9, immagine 1 di 2 Nikon Coolpix L820 Device Ports Replacement: passo 9, immagine 2 di 2
    • Using the pointed end of the spudger, lift the hinges that secure these four flex circuits.
  10. Nikon Coolpix L820 Device Ports Replacement: passo 10, immagine 1 di 2 Nikon Coolpix L820 Device Ports Replacement: passo 10, immagine 2 di 2
    • Once the flex circuits are removed, the motherboard can be lifted and the device can be accessed for replacement.
    DO NOT “just lift the motherboard"! The motherboard is soldered to a daughterboard for the power button and for the battery compartment. If you do forcibly lift the motherboard you will rip some solder pads off. You need to desolder the motherboard from the daughterboard FIRST before attempting to flip up the motherboard. AFTER desoldering the motherboard there is a singular screw holding in the board in the top left, remove that too!
    Braxton - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
Marc
Membro da: 03/23/15
430 Reputazione
3 Guide realizzate
Un commento
Could you explain how the power button is changed? Thank you!!
minigalinda - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,970
