Salta al contenuto principale
Nikon Coolpix L330 Motherboard Replacement
Mohammed Al Rawahi
Mohammed Al Rawahi e 3 altri collaboratori
Ultimo aggiornamento il June 28, 2020
30 - 40 minuti
Difficile
Introduzione
Vai al passo 1
If you encounter issues with your camera motherboard, follow this step by step guide to aid you on replacing it.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nikon Coolpix L330 Motherboard Replacement, Back Housing: passo 1, immagine 1 di 3 Nikon Coolpix L330 Motherboard Replacement, Back Housing: passo 1, immagine 2 di 3 Nikon Coolpix L330 Motherboard Replacement, Back Housing: passo 1, immagine 3 di 3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Motherboard Replacement: passo 2, immagine 1 di 2 Nikon Coolpix L330 Motherboard Replacement: passo 2, immagine 2 di 2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
  3. Nikon Coolpix L330 Motherboard Replacement, LCD Screen: passo 3, immagine 1 di 2 Nikon Coolpix L330 Motherboard Replacement, LCD Screen: passo 3, immagine 2 di 2
    • Insert the tips of your fingers into the space between the screen and back-plate.
    • Gently lift the screen up and out of the frame.
    • The screen is still held by a flexible display cable, therefore only lift the screen 0.5'' out of the back-plate.
  4. Nikon Coolpix L330 Motherboard Replacement: passo 4, immagine 1 di 2 Nikon Coolpix L330 Motherboard Replacement: passo 4, immagine 2 di 2
    • Tilt the screen so that the display cable forms a hinge with the backplate.
    • Rotate the display 180 degrees so that it faces you.
  5. Nikon Coolpix L330 Motherboard Replacement: passo 5, immagine 1 di 3 Nikon Coolpix L330 Motherboard Replacement: passo 5, immagine 2 di 3 Nikon Coolpix L330 Motherboard Replacement: passo 5, immagine 3 di 3
    • The display cable has a ZIF (zero insertion force) connector on the end. This has a tab that has to be pushed out before the cable can be safely removed.
    • Using a plastic opening tool or fingernail, pop up the black clip holding the display cable. This will release the cable.
    • Slide the display cable out of the connector.
    • The display cable can be damaged due to excessive bending, therefore avoid putting unnecessary strain on it.
  6. Nikon Coolpix L330 Motherboard Replacement, Motherboard: passo 6, immagine 1 di 1
    • Remove the screws from the silver back-plate with a PH000 screw head.
    • Two 1.5x2.5mm screws on the left side.
    • One 1.5x2.5mm screw on the right side.
  7. Nikon Coolpix L330 Motherboard Replacement: passo 7, immagine 1 di 1
    • The marked red box contains a highly charged capacitor. Check the charge using a voltmeter and discharge it first before continuing. Discharge capacitor guide.
    • Remove the screws holding the motherboard with a PH000 screw head.
  8. Nikon Coolpix L330 Motherboard Replacement: passo 8, immagine 1 di 1
    • Using a plastic opening tool or fingernail, pop up the black clips holding the ribbon cables. This will release the cables.
    • Slide the ribbon cables out of the connectors.
  9. Nikon Coolpix L330 Motherboard Replacement: passo 9, immagine 1 di 3 Nikon Coolpix L330 Motherboard Replacement: passo 9, immagine 2 di 3 Nikon Coolpix L330 Motherboard Replacement: passo 9, immagine 3 di 3
    • Remove the black sticker covering the electrical connections.
    • Desolder the eight wires from the motherboard.
  10. Nikon Coolpix L330 Motherboard Replacement: passo 10, immagine 1 di 3 Nikon Coolpix L330 Motherboard Replacement: passo 10, immagine 2 di 3 Nikon Coolpix L330 Motherboard Replacement: passo 10, immagine 3 di 3
    • Insert a plastic opening tool into the marked position. Push the tool towards the right to release the clip.
    • Using a thumb and forefinger, push the plastic cover up until it is at a 45 degree angle.
    • Pull the cover back and up to release it.
  11. Nikon Coolpix L330 Motherboard Replacement: passo 11, immagine 1 di 2 Nikon Coolpix L330 Motherboard Replacement: passo 11, immagine 2 di 2
    • The motherboard is still held in place by soldered connections.
    • Carefully desolder the connections .
    • The front cover has been removed in this picture, however the procedure is still the same.
  12. Nikon Coolpix L330 Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the motherboard by lifting it directly up.
Conclusione
USF Tampa, Team 2-10, Cagle Spring 2016 Membro di USF Tampa, Team 2-10, Cagle Spring 2016
USFT-CAGLE-S16S2G10
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 8
Tutti i Tempi: 834
