Nikon Coolpix B700 LCD Screen Replacement
Introduzione
Vai al passo 1The LCD screen can be easily replaced without removing any other parts from the device. If the LCD screen is cracked or the backlight is inoperable, refer to this replacement guide.
Cosa ti serve
Use a Phillips screwdriver to remove the two 3.5mm screws at the top and bottom of the LCD Screen.
Attrezzo utilizzato in questo passaggio:Desoldering Pump$3.99
Use the solder gun and desolder the yellow and blue wires.
Use the jimmy and slide it in between the LCD screen and lift out the LCD Screen.
Bonjour,
Ce tutoriel est vraiment super,mais oú peut on trouver l'écran de rechange ? Ai commandé sur internet et pas reçu le même modèle
Altre 2 persone hanno completato questa guida.
2Commenti sulla guida
Hi, I like the first 6 steps, but what are the rest of the steps?
