Salta al contenuto principale
Nikon Coolpix AW130 Front Panel Replacement
Lauren Stepp
Lauren Stepp e un altro collaboratore
Ultimo aggiornamento il June 17, 2020
5 minuti
Facile
Introduzione
Vai al passo 1
Removing the front face is necessary if the colored plate is damaged. This process is also a prerequisite for various other repairs.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nikon Coolpix AW130 Front Panel Replacement, Battery: passo 1, immagine 1 di 2 Nikon Coolpix AW130 Front Panel Replacement, Battery: passo 1, immagine 2 di 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Front Panel Replacement: passo 2, immagine 1 di 2 Nikon Coolpix AW130 Front Panel Replacement: passo 2, immagine 2 di 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Front Panel Replacement: passo 3, immagine 1 di 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
    This yellow tab spring broken, how I can repair
    Surendra kumar - Replica
    From where I can get this yellow tab, and how I can replace
  4. Nikon Coolpix AW130 Front Panel Replacement: passo 4, immagine 1 di 2 Nikon Coolpix AW130 Front Panel Replacement: passo 4, immagine 2 di 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Front Panel Replacement, Front Panel: passo 5, immagine 1 di 2 Nikon Coolpix AW130 Front Panel Replacement, Front Panel: passo 5, immagine 2 di 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
    ChK 2022_01_27: There is no need to remove the front panel in order to get to the main board. Skip this step.
    Christoph Kunz - Replica
  6. Nikon Coolpix AW130 Front Panel Replacement: passo 6, immagine 1 di 2 Nikon Coolpix AW130 Front Panel Replacement: passo 6, immagine 2 di 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
    I think this step is unnecessary, and it´s very hard to take off this metal plate without damage
    Mauricio Almeida - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
1Commento della guida
Hello, has this front panel influence on cameras sealing function? Or is it only as shield against mechanical demage?
Slavomir - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,546
