Salta al contenuto principale
Nikon COOLPIX P500 Front Case Replacement
Kevin Scott
Kevin Scott e 5 altri collaboratori
Ultimo aggiornamento il July 10, 2020
30 minuti - 2 ore
Difficile
Necessarie Immagini Migliori
Prerequisiti Non Soddisfatti
Introduzione
Vai al passo 1
This guide will demonstrate how to isolate the front case of the camera from the rest of the device.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nikon COOLPIX P500 Front Case Replacement, Battery: passo 1, immagine 1 di 2 Nikon COOLPIX P500 Front Case Replacement, Battery: passo 1, immagine 2 di 2
    • Electric shock is a huge risk if the battery is not removed while taking the camera apart.
    • Press down and forward on the battery cover latch.
    • Push the orange latch, in the direction of the arrow on it, to release the battery.
  2. Nikon COOLPIX P500 Front Case Replacement, Motherboard: passo 2, immagine 1 di 3 Nikon COOLPIX P500 Front Case Replacement, Motherboard: passo 2, immagine 2 di 3 Nikon COOLPIX P500 Front Case Replacement, Motherboard: passo 2, immagine 3 di 3
    • Remove all the marked screws using a PH00 screwdriver.
    • Remove the two 3mm screws on the grip.
    • Remove the two 4mm screws on the side opposite the grip.
    • Remove the three 4mm screws on the base of the camera.
    • Remove the four 3mm screws on the base of the camera.
    Before separate the two parts of the body of the camera as described in step 3, we have to remove the two screws hide behind the screen (at the base of the gear)
    donthavetoknnow - Replica
    Before to separate the two parts of the body of the camera as described in step 3, we have to remove the two screws behind the screen, in the base of the system that connect it to the camera
    Yes Indeed a step was forgotten. You need to flip open the flash module. Now you can remove a small screw from the front that holds the stereo L R microphone in place, after that carefully remove the microphone cover. After that you will see a screw from the top view where the cover of the microphone was removed. When this screw is removed the back cover comes off. Please be careful because there are two ribbon cables, one for the buttons and one for the LCD screen.
    PS I still have problems after replacing the complete lens assembly with sensor. I think Nikon updated the firmware and something in the firmware is faulty. Because I can still record movies but cannot make pictures (shutter button works)… Yes I tried hard reset, factory reset. No luck at all. The backup battery in my device is flat also…. Maybe I should buy another camera. No more Nikon for sure. Camera wasn't even used that much, meh ..
    Roger L. Ortiz - Replica
  3. Nikon COOLPIX P500 Front Case Replacement, Removing hidden screws: passo 3, immagine 1 di 2 Nikon COOLPIX P500 Front Case Replacement, Removing hidden screws: passo 3, immagine 2 di 2
    • Open the flash module of the camera.
    • Remove the 2mm screw from the microphone metal grid using a PH00 screwdriver.
    • Remove the 4mm screw that was under the metal microphone grid using a PH00 screwdriver.
  4. Nikon COOLPIX P500 Front Case Replacement: passo 4, immagine 1 di 2 Nikon COOLPIX P500 Front Case Replacement: passo 4, immagine 2 di 2
    • Separate the two parts of the body of the camera slightly.
    • Release the two cables by lifting up their respective clips with a spudger.
    • Make sure not to pull too hard because there are connector ribbons.
    • Detach the connector ribbons before fully separating the camera into two pieces.
    • These pictures were taken after the connector ribbons were released and the camera was separated into two parts. You will need to release the connector ribbons while the camera is still in one piece before you can separate it like the pictures.
    Before to separate the two parts of the body of the camera, we have to remove the two screws behind the screen and the screw under the speakers
  5. Nikon COOLPIX P500 Front Case Replacement: passo 5, immagine 1 di 1
    • Use a spudger to flip up the cable lock in order to release the ribbon.
  6. Nikon COOLPIX P500 Front Case Replacement: passo 6, immagine 1 di 2 Nikon COOLPIX P500 Front Case Replacement: passo 6, immagine 2 di 2
    • Use a PH00 screwdriver to unscrew the four labeled 3mm metal screws on the metal backing.
    • Remove the four labeled 4mm screws connected to the motherboard.
    • Remove the metal support.
  7. Nikon COOLPIX P500 Front Case Replacement: passo 7, immagine 1 di 2 Nikon COOLPIX P500 Front Case Replacement: passo 7, immagine 2 di 2
    • Desolder the labeled soldering points.
    • Soldering irons are very hot. They can damage your device and inflict physical harm if proper care is not taken.
  8. Nikon COOLPIX P500 Front Case Replacement: passo 8, immagine 1 di 2 Nikon COOLPIX P500 Front Case Replacement: passo 8, immagine 2 di 2
  9. Nikon COOLPIX P500 Front Case Replacement: passo 9, immagine 1 di 3 Nikon COOLPIX P500 Front Case Replacement: passo 9, immagine 2 di 3 Nikon COOLPIX P500 Front Case Replacement: passo 9, immagine 3 di 3
    • Use a spudger to unlock the labeled connector ribbons.
    • Disconnect the labeled connector ribbons.
  10. Nikon COOLPIX P500 Front Case Replacement: passo 10, immagine 1 di 2 Nikon COOLPIX P500 Front Case Replacement: passo 10, immagine 2 di 2
    • Use a spudger to unlock the two connector ribbons.
    • Disconnect the two connector ribbons.
  11. Nikon COOLPIX P500 Front Case Replacement: passo 11, immagine 1 di 1
    • Remove the mother board from the camera.
  12. Nikon COOLPIX P500 Front Case Replacement, Front Case: passo 12, immagine 1 di 2 Nikon COOLPIX P500 Front Case Replacement, Front Case: passo 12, immagine 2 di 2
    • Use a PH00 screwdriver to remove the three labeled 3mm screws.
  13. Nikon COOLPIX P500 Front Case Replacement: passo 13, immagine 1 di 1
    • Remove the black plastic holding the image sensor from the camera. You now have access to the front casing of the camera.
Conclusione
Kevin Scott
Membro da: 01/22/15
517 Reputazione
3 Guide realizzate
Cal Poly, Team 19-10, Maness Winter 2015 Membro di Cal Poly, Team 19-10, Maness Winter 2015
CPSU-MANESS-W15S19G10
4 Membri
14 Guide realizzate
2Commenti sulla guida
The manual is incomplete. There are several screws that need to be removed and are not mentioned in the manual. Also desolder the contacts to the battery, which are not mentioned in the manual ...
Juan Vivo - Replica
Resolveu a minha vida. Eu estava com problemas de fungos no sensor.
consegui desmontar e limpar.
Valdecyr Villaça - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,682
