Nerf N-Strike Maverick Catch Spring Replacement
Introduzione
Vai al passo 1The catch spring is a small, but vital part of the catching mechanism. It gives some of the tension necessary for the catch to latch on to the plunger. Without it, the catch will not spring back into place after firing the gun.
Cosa ti serve
Strumenti
Use the Teardown Guide through step six to open the gun.
Remove the catch mechanism and spring by gently lifting it straight up and off the metal pin that holds it.
After removing the old catch spring, place the new catch spring back on the tip of the catch mechanism.
Thanks for the tip about the pen spring. I had the original ping out into some corner of my work space just before finishing reassembly.
Carefully replace the catch mechanism so that it is seated in the grooves and over the metal pin.
Altre 4 persone hanno completato questa guida.
1Commento della guida
do you have a spare catch spring the whole catch mechanism and spring
