Nerf N-Strike Elite Alpha Trooper CS-12 Firing Spring Replacement
Introduzione
Vai al passo 1If the firing spring becomes dislodged or damaged, your rifle may have reduced firing ability, or may not fire at all. This guide shows you how to access and replace the primary firing spring in the Nerf N-Strike Elite Alpha Trooper CS-12.
This guide may also be used when upgrading the firing spring on your rifle.
Cosa ti serve
Be sure that the rifle is discharged and unloaded before starting disassembly.
Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
Pull off the orange cap.
With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
Separate and remove the two halves of the slide mechanism.
You should now be able to pull the main firing spring from the rear of the rifle.
Altre 2 persone hanno completato questa guida.
