Salta al contenuto principale
Motorola Moto G60S Display Replacement
Cosa ti serve
  1. Motorola Moto G60S Display Replacement, Prepare your phone for disassembly: passo 1, immagine 1 di 2 Motorola Moto G60S Display Replacement, Prepare your phone for disassembly: passo 1, immagine 2 di 2
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your phone and unplug any cables.
  2. Motorola Moto G60S Display Replacement, Remove the SIM card tray: passo 2, immagine 1 di 3 Motorola Moto G60S Display Replacement, Remove the SIM card tray: passo 2, immagine 2 di 3 Motorola Moto G60S Display Replacement, Remove the SIM card tray: passo 2, immagine 3 di 3
    • Insert a SIM eject tool, bit, or straightened paperclip into the SIM card tray hole on the left edge of the phone.
    • Push the SIM eject tool into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  3. Motorola Moto G60S Display Replacement, Heat the right edge: passo 3, immagine 1 di 1
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Motorola Moto G60S Display Replacement, Insert an opening pick: passo 4, immagine 1 di 2 Motorola Moto G60S Display Replacement, Insert an opening pick: passo 4, immagine 2 di 2
    • Flip your phone over so the display is facing up.
    • Apply a suction handle to the middle of the display's left edge, as close to the edge as possible.
    • Place the tip of an opening pick in the small gap between the back cover and the display.
    • Pull up on the suction cup with a strong, steady force and push the opening pick down at a 45 degree angle until it slides into the gap between the back cover and the display.
    • If you're having a hard time inserting the pick, reheat the adhesive with an iOpener and try again.
  5. Motorola Moto G60S Display Replacement, Slice the left adhesive: passo 5, immagine 1 di 3 Motorola Moto G60S Display Replacement, Slice the left adhesive: passo 5, immagine 2 di 3 Motorola Moto G60S Display Replacement, Slice the left adhesive: passo 5, immagine 3 di 3
    • Both adhesive and clips secure the back cover.
    • During steps that involve sliding the opening pick, keep it angled down at a 45 degree angle.
    • Slide the pick along the left edge down to the bottom left corner, and then up to the top left corner, to release the clips and slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
  6. Motorola Moto G60S Display Replacement, Heat the top edge: passo 6, immagine 1 di 1
    • Flip your phone over and apply a heated iOpener to the back cover's top edge for two minutes.
  7. Motorola Moto G60S Display Replacement: passo 7, immagine 1 di 2 Motorola Moto G60S Display Replacement: passo 7, immagine 2 di 2
    • Flip your phone over and rotate the pick around the top left corner.
  8. Motorola Moto G60S Display Replacement: passo 8, immagine 1 di 2 Motorola Moto G60S Display Replacement: passo 8, immagine 2 di 2
    • Slide the pick along the top edge to release the clips and slice the adhesive.
    • Leave the pick inserted in the top right corner.
  9. Motorola Moto G60S Display Replacement: passo 9, immagine 1 di 1
    • Flip your phone over and apply a heated iOpener to the back cover's left edge for two minutes.
  10. Motorola Moto G60S Display Replacement: passo 10, immagine 1 di 2 Motorola Moto G60S Display Replacement: passo 10, immagine 2 di 2
    • Flip your phone over and rotate the pick around the top right corner.
  11. Motorola Moto G60S Display Replacement: passo 11, immagine 1 di 2 Motorola Moto G60S Display Replacement: passo 11, immagine 2 di 2
    • Slide the pick along the right edge to release the clips and slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
  12. Motorola Moto G60S Display Replacement: passo 12, immagine 1 di 1
    • Flip your phone over and apply a heated iOpener to the back cover's bottom edge for two minutes.
  13. Motorola Moto G60S Display Replacement: passo 13, immagine 1 di 2 Motorola Moto G60S Display Replacement: passo 13, immagine 2 di 2
    • Flip your phone over and rotate the pick around the bottom right corner.
  14. Motorola Moto G60S Display Replacement: passo 14, immagine 1 di 2 Motorola Moto G60S Display Replacement: passo 14, immagine 2 di 2
    • Slide the opening pick along the bottom edge to release the clips and slice the adhesive.
  15. Motorola Moto G60S Display Replacement: passo 15, immagine 1 di 2 Motorola Moto G60S Display Replacement: passo 15, immagine 2 di 2
    • Flip your phone over and apply a heated iOpener to the fingerprint sensor on the back cover for two minutes.
  16. Motorola Moto G60S Display Replacement, Detach the fingerprint sensor: passo 16, immagine 1 di 3 Motorola Moto G60S Display Replacement, Detach the fingerprint sensor: passo 16, immagine 2 di 3 Motorola Moto G60S Display Replacement, Detach the fingerprint sensor: passo 16, immagine 3 di 3
    • Adhesive secures the fingerprint sensor to the back case.
    • A fragile cable secures the fingerprint sensor to the motherboard. Be very careful during this step to avoid damaging the cable.
    • Press down on the fingerprint sensor with the flat end of a spudger or your finger.
    • While pressing down on the fingerprint sensor, gently pull up the bottom edge of the back cover until the sensor detaches.
  17. Motorola Moto G60S Display Replacement, Remove the back cover: passo 17, immagine 1 di 3 Motorola Moto G60S Display Replacement, Remove the back cover: passo 17, immagine 2 di 3 Motorola Moto G60S Display Replacement, Remove the back cover: passo 17, immagine 3 di 3
    • Lift the back cover up and remove it.
    • If the back cover is still stuck to the frame, slide an opening pick around the entire perimeter until the cover separates completely.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • Apply new adhesive to the perimeter of the underside of the back cover after cleaning the relevant areas with isopropyl alcohol (>90%) and a micro-fiber cloth.
  18. Motorola Moto G60S Display Replacement, Detach the fingerprint sensor: passo 18, immagine 1 di 2 Motorola Moto G60S Display Replacement, Detach the fingerprint sensor: passo 18, immagine 2 di 2
    • The fingerprint reader is secured to the motherboard cover with light adhesive.
    • Insert the flat end of a spudger under the fingerprint sensor.
    • Gently pry up and detach the fingerprint sensor from the motherboard cover.
    • Don't try to remove the fingerprint sensor yet, as it's still attached to the motherboard by a delicate ribbon cable.
  19. Motorola Moto G60S Display Replacement, Unfasten the motherboard cover: passo 19, immagine 1 di 2 Motorola Moto G60S Display Replacement, Unfasten the motherboard cover: passo 19, immagine 2 di 2
    • Use a Phillips screwdriver to remove the seven 3.9 mm screws securing the motherboard cover.
  20. Motorola Moto G60S Display Replacement, Unclip the motherboard cover: passo 20, immagine 1 di 2 Motorola Moto G60S Display Replacement, Unclip the motherboard cover: passo 20, immagine 2 di 2
    • The motherboard cover is secured with tight clips.
    • Insert the flat end of a spudger in the gap between the frame and the bottom left corner of the motherboard cover.
    • Lift straight up with the spudger to release the clips securing the motherboard.
    • Don't pry against the battery, as this could damage it.
    • This may take take a few attempts. It you're having trouble, try gripping the spudger closer to the flat end.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  21. Motorola Moto G60S Display Replacement, Remove the motherboard cover: passo 21, immagine 1 di 2 Motorola Moto G60S Display Replacement, Remove the motherboard cover: passo 21, immagine 2 di 2
    • Pull the motherboard cover towards the top of the phone to remove it.
    • Make sure to avoid the fingerprint sensor cable when removing the cover, as it can easily rip.
  22. Motorola Moto G60S Display Replacement, Disconnect the battery: passo 22, immagine 1 di 2 Motorola Moto G60S Display Replacement, Disconnect the battery: passo 22, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the battery cable's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  23. Motorola Moto G60S Display Replacement, Detach the graphite film: passo 23, immagine 1 di 2 Motorola Moto G60S Display Replacement, Detach the graphite film: passo 23, immagine 2 di 2
    • Adhesive lightly adheres graphite film to the battery.
    • Don't puncture the battery—it can leak dangerous chemicals and/or catch fire.
    • Insert the pointed end of a spudger under the graphite film on the left side of the daughterboard cover.
    • Lift up to peel the graphite film off of the battery.
  24. Motorola Moto G60S Display Replacement, Apply isopropyl alcohol: passo 24, immagine 1 di 2 Motorola Moto G60S Display Replacement, Apply isopropyl alcohol: passo 24, immagine 2 di 2
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol to the gaps along the battery's edges.
    • Tilt the device to help it flow under the battery.
    • Wait one minute to allow the isopropyl alcohol to penetrate the adhesive.
    • Only apply a few drops initially and apply more as necessary. If you apply too much alcohol, it may overflow onto the motherboard or daughterboard and damage components like front or rear cameras.
  25. Motorola Moto G60S Display Replacement, Separate the battery's adhesive: passo 25, immagine 1 di 3 Motorola Moto G60S Display Replacement, Separate the battery's adhesive: passo 25, immagine 2 di 3 Motorola Moto G60S Display Replacement, Separate the battery's adhesive: passo 25, immagine 3 di 3
    • Take care not to puncture or bend the battery during the removal process—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Apply a suction cup to middle of the battery.
    • Pull up on the suction cup with strong, steady force to separate the battery from the frame.
    • If the battery doesn't budge, apply a few more drops of isopropyl alcohol, wait one minute, and try again.
    • Continue to pull up on the suction cup while sliding the opening pick back and forth to slice the adhesive.
    • Continue this process until the battery separates from the frame, applying isopropyl alcohol as necessary.
  26. Motorola Moto G60S Display Replacement, Remove the battery: passo 26, immagine 1 di 2 Motorola Moto G60S Display Replacement, Remove the battery: passo 26, immagine 2 di 2
    • Remove the battery from the frame.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Follow this guide to install new battery adhesive.
  27. Motorola Moto G60S Display Replacement, Transfer the battery foam strip: passo 27, immagine 1 di 3 Motorola Moto G60S Display Replacement, Transfer the battery foam strip: passo 27, immagine 2 di 3 Motorola Moto G60S Display Replacement, Transfer the battery foam strip: passo 27, immagine 3 di 3
    • If you're replacing the battery:
    • Use your fingers to remove the foam strip from the old battery's bottom edge.
    • Apply the foam strip to the bottom edge of the replacement battery.
  28. Motorola Moto G60S Display Replacement, Disconnect the display: passo 28, immagine 1 di 2 Motorola Moto G60S Display Replacement, Disconnect the display: passo 28, immagine 2 di 2
    • Use a spudger to pry up and disconnect the display's press connector.
    • Pry on the corner of the press connector closest to the left edge of the phone to avoid damaging the depth camera.
  29. Motorola Moto G60S Display Replacement, Detach the display cable: passo 29, immagine 1 di 2 Motorola Moto G60S Display Replacement, Detach the display cable: passo 29, immagine 2 di 2
    • Gently pull the display's ribbon cable up and towards the bottom of the phone until it's completely separated from the frame.
    • If you are having trouble detaching the cable, apply a heated iOpener to it and try again.
  30. Motorola Moto G60S Display Replacement, Reattach the back cover: passo 30, immagine 1 di 2 Motorola Moto G60S Display Replacement, Reattach the back cover: passo 30, immagine 2 di 2
    • The remaining steps risk damaging the exposed cameras, spring connectors, and motherboard. Temporarily reinstalling the back cover protects these parts.
    • Place the back cover on the frame and press around the perimeter to engage the clips.
    • During reassembly, remove the back cover.
    • You can skip steps that involve heating, as the adhesive should no longer form a strong bond.
  31. Motorola Moto G60S Display Replacement, Heat the top edge: passo 31, immagine 1 di 1
    • Flip your phone over.
    • Apply a heated iOpener to the display's top edge for two minutes.
  32. Motorola Moto G60S Display Replacement, Insert an opening pick: passo 32, immagine 1 di 3 Motorola Moto G60S Display Replacement, Insert an opening pick: passo 32, immagine 2 di 3 Motorola Moto G60S Display Replacement, Insert an opening pick: passo 32, immagine 3 di 3
    • The adhesive securing the screen is extremely strong, and inserting an opening pick requires significant force. If you're having trouble, apply more heat and try again.
    • Apply a suction cup to the center of the display's top edge, as close to the edge as possible.
    • Insert an opening pick in the earpiece speaker cutout on the top edge of the display.
    • Pull up on the suction cup with strong, steady force.
    • Angle the opening pick to about 30 degrees and push it towards the center of the phone until it slides under the display.
    • Be careful not to damage the earpiece speaker mesh when trying to insert the pick.
    • Slide the opening pick to the top right corner of the display.
  33. Motorola Moto G60S Display Replacement: passo 33, immagine 1 di 2 Motorola Moto G60S Display Replacement: passo 33, immagine 2 di 2
    • During the next three steps, don't insert your pick more than 2 mm to avoid damaging the display.
    • Slide the opening pick toward the bottom right corner to separate the right edge's adhesive.
  34. Motorola Moto G60S Display Replacement: passo 34, immagine 1 di 2 Motorola Moto G60S Display Replacement: passo 34, immagine 2 di 2
    • Slide the opening pick around the bottom corners to separate the bottom edge's adhesive.
  35. Motorola Moto G60S Display Replacement: passo 35, immagine 1 di 2 Motorola Moto G60S Display Replacement: passo 35, immagine 2 di 2
    • Slide the pick toward the top left corner to separate the remaining adhesive.
  36. Motorola Moto G60S Display Replacement, Remove the display: passo 36, immagine 1 di 3 Motorola Moto G60S Display Replacement, Remove the display: passo 36, immagine 2 di 3 Motorola Moto G60S Display Replacement, Remove the display: passo 36, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Pull the the display up and towards the bottom of the phone, making sure to gently thread the display cable through its slot.
    • Remove the display.
    • Remove the old adhesive with tweezers or your fingers and clean the frame with isopropyl alcohol (>90%) and a micro-fiber cloth.
    • Apply new adhesive where the old adhesive was.
    • Follow this guide if you're using a precut adhesive card.
    • Thread the display cable through its slot in the frame.
    • Press down firmly around the perimeter of the replacement display to secure it to the frame.
Conclusione
To reassemble your device, follow the instructions in reverse order.
Spencer Day
Membro da: 09/14/22
61.610 Reputazione
445 Guide realizzate
iFixit Membro di iFixit
Staff
140 Membri
18.077 Guide realizzate
Un commento
Please mention that you need adhesive at the beginning of the guide
silvestre donselaar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 106
Tutti i Tempi: 1,160
