Introduzione
Follow this guide to remove and replace the wide angle camera on a Motorola Edge.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Cosa ti serve
Heat an iOpener, then apply it along the bottom edge of the back cover for two minutes.
Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert an opening pick into the gap.
Slide the pick back and forth along the bottom edge to slice through the adhesive.
Leave the pick in to prevent the adhesive from resealing.
Apply a heated iOpener to the back cover's right edge for two minutes.
Rotate the opening pick around the bottom-right corner of the phone.
Insert a new opening pick into the gap you just created.
Slide the pick along the right edge of the phone to separate the adhesive.
Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
Remove the back cover, taking care not to damage the components inside the phone.
Use a T5 Torx screwdriver to remove the twelve 3.4 mm-long screws securing the motherboard cover.
Use a pair of blunt tweezers or your fingers to lift up and remove the motherboard cover.
Use a spudger to pry up and disconnect the battery cable's press connector from the motherboard.
Use a spudger to pry up the wide angle camera cable's press connector and disconnect it from the motherboard.
Remove the wide angle camera.
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
