Salta al contenuto principale
Motor and Pump Assembly Removal
Sam Omiotek
Sam Omiotek e un altro collaboratore
Ultimo aggiornamento il March 23, 2021
30 minuti - 1 ora
Moderato
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Introduzione
Vai al passo 1
Follow this guide to remove the motor and pump assembly from a Mi-T-M heater model MH-0190-0M10.
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
  1. Motor and Pump Assembly Removal, Safety precautions: passo 1, immagine 1 di 2 Motor and Pump Assembly Removal, Safety precautions: passo 1, immagine 2 di 2
    • Power off the machine at least one hour prior to starting repairs. Ensure the machine is completely cool to the touch.
    • Flip the power switch into the OFF position.
    • Unplug any extension cords from the included power cord.
  2. Motor and Pump Assembly Removal, Remove the upper shell: passo 2, immagine 1 di 2 Motor and Pump Assembly Removal, Remove the upper shell: passo 2, immagine 2 di 2
    • Use a 5/16 inch socket or Phillips screwdriver to remove the eight screws securing the upper shell, four on each side.
  3. Motor and Pump Assembly Removal: passo 3, immagine 1 di 2 Motor and Pump Assembly Removal: passo 3, immagine 2 di 2
    • Lift the upper shell straight up off of the machine to remove it.
  4. Motor and Pump Assembly Removal, Remove the right-side cover: passo 4, immagine 1 di 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the right-side cover.
  5. Motor and Pump Assembly Removal: passo 5, immagine 1 di 3 Motor and Pump Assembly Removal: passo 5, immagine 2 di 3 Motor and Pump Assembly Removal: passo 5, immagine 3 di 3
    • Tilt the right-side cover down to access the PCB board.
    • Do not fully remove the right-side cover, it is still attached via the on/off switch.
    • During reassembly, ensure the display window is aligned with the LCD display before you press the cover into place.
  6. Motor and Pump Assembly Removal: passo 6, immagine 1 di 3 Motor and Pump Assembly Removal: passo 6, immagine 2 di 3 Motor and Pump Assembly Removal: passo 6, immagine 3 di 3
    • There are two wires connecting the power switch to the main PCB assembly.
    • Use needle nose pliers to remove the wire with the blue connector.
    • Remove the wire with the clear connector.
    • Remove the right-side cover.
    • During reassembly, install the power switch wires back in their original locations with the blue wire above the clear wire.
  7. Motor and Pump Assembly Removal, Disconnect the ground wires: passo 7, immagine 1 di 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the screw securing the two green ground wires to the frame.
  8. Motor and Pump Assembly Removal, Disconnect the fuel line: passo 8, immagine 1 di 3 Motor and Pump Assembly Removal, Disconnect the fuel line: passo 8, immagine 2 di 3 Motor and Pump Assembly Removal, Disconnect the fuel line: passo 8, immagine 3 di 3
    • Use a pair of needle nose pliers to release the hose clamp from the fuel line.
    • Slide the hose clamp off of the nipple, about one inch down the fuel line.
  9. Motor and Pump Assembly Removal: passo 9, immagine 1 di 2 Motor and Pump Assembly Removal: passo 9, immagine 2 di 2
    • Pull to disconnect the fuel line from the motor and pump assembly.
  10. Motor and Pump Assembly Removal: passo 10, immagine 1 di 2 Motor and Pump Assembly Removal: passo 10, immagine 2 di 2
    • Use a pair of needle nose pliers to remove the fuel line hose clamp.
  11. Motor and Pump Assembly Removal, Disconnect the motor and pump assembly: passo 11, immagine 1 di 2 Motor and Pump Assembly Removal, Disconnect the motor and pump assembly: passo 11, immagine 2 di 2
    • Use a pair of needle nose pliers to disconnect the wires connecting the motor and pump assembly to the main PCB board:
    • One red cable labeled MOTOR 2 on the main PCB board
    • One orange cable labeled MOTOR 1 on the main PCB board
    • Pull the wires with the needle nose pliers by their connectors and not the wires themselves.
  12. Motor and Pump Assembly Removal: passo 12, immagine 1 di 3 Motor and Pump Assembly Removal: passo 12, immagine 2 di 3 Motor and Pump Assembly Removal: passo 12, immagine 3 di 3
    • Use a pair of flush cutters to cut the cable tie harnessing the wires running from the main PCB assembly.
    • Remove the cable tie.
    • During reassembly, install a new cable tie.
  13. Motor and Pump Assembly Removal: passo 13, immagine 1 di 2 Motor and Pump Assembly Removal: passo 13, immagine 2 di 2
    • Use a pair of flush cutters to cut the cable tie harnessing the orange, red, white, and black wires near the fuel line.
  14. Motor and Pump Assembly Removal: passo 14, immagine 1 di 2 Motor and Pump Assembly Removal: passo 14, immagine 2 di 2
    • Use a pair of flush cutters to cut the cable tie harnessing the orange and red wires next to the motor.
  15. Motor and Pump Assembly Removal, Detach the capacitor: passo 15, immagine 1 di 1
    • Use a Phillips screwdriver to remove the screw securing the capacitor band clamp.
  16. Motor and Pump Assembly Removal: passo 16, immagine 1 di 3 Motor and Pump Assembly Removal: passo 16, immagine 2 di 3 Motor and Pump Assembly Removal: passo 16, immagine 3 di 3
    • Remove the capacitor from the band clamp.
    • During reassembly, realign the foam padding between the capacitor and the band clamp.
  17. Motor and Pump Assembly Removal, Remove the motor and pump assembly: passo 17, immagine 1 di 3 Motor and Pump Assembly Removal, Remove the motor and pump assembly: passo 17, immagine 2 di 3 Motor and Pump Assembly Removal, Remove the motor and pump assembly: passo 17, immagine 3 di 3
    • Feed the orange and red wires out through the opening in the lower shell.
  18. Motor and Pump Assembly Removal: passo 18, immagine 1 di 1
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four bolts securing the left-side cover.
  19. Motor and Pump Assembly Removal: passo 19, immagine 1 di 3 Motor and Pump Assembly Removal: passo 19, immagine 2 di 3 Motor and Pump Assembly Removal: passo 19, immagine 3 di 3
    • Remove the left-side cover.
  20. Motor and Pump Assembly Removal: passo 20, immagine 1 di 2 Motor and Pump Assembly Removal: passo 20, immagine 2 di 2
    • Use a 5/16 inch socket or Phillips screwdriver to remove the four screws securing the motor mount bracket, two on each side.
  21. Motor and Pump Assembly Removal: passo 21, immagine 1 di 2 Motor and Pump Assembly Removal: passo 21, immagine 2 di 2
    • Lift the motor, pump, and bracket assembly straight up out of the machine.
Conclusione
Sam Omiotek
Membro da: 02/25/19
84.442 Reputazione
290 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 4
