Salta al contenuto principale
Motherboard Removal
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Motherboard Removal, Heat the bottom edge: passo 1, immagine 1 di 1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device to loosen the adhesive underneath.
    • The display adhesive of the Galaxy Tab S7+ is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  2. Motherboard Removal, Screen removal information: passo 2, immagine 1 di 3 Motherboard Removal, Screen removal information: passo 2, immagine 2 di 3 Motherboard Removal, Screen removal information: passo 2, immagine 3 di 3
    • While you're waiting for the adhesive to loosen, note the following:
    • There's a long circuit board attached to the screen that sits parallel to the bottom edge.
    • Don't insert the pick more than 2 mm to avoid damaging the circuit board.
    • This image shows an example of the display separating from the glass panel.
    • Don't insert the pick more than 3 mm to avoid damaging the display.
  3. Motherboard Removal, Insert an opening pick: passo 3, immagine 1 di 3 Motherboard Removal, Insert an opening pick: passo 3, immagine 2 di 3 Motherboard Removal, Insert an opening pick: passo 3, immagine 3 di 3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Motherboard Removal, Separate the bottom adhesive: passo 4, immagine 1 di 3 Motherboard Removal, Separate the bottom adhesive: passo 4, immagine 2 di 3 Motherboard Removal, Separate the bottom adhesive: passo 4, immagine 3 di 3
    • Insert a new opening pick into the gap you created.
    • Slide the new pick along the bottom edge of the device towards the bottom-right corner.
  5. Motherboard Removal, Heat the right edge: passo 5, immagine 1 di 1
    • Apply a heated iOpener to the right edge of the device to loosen the adhesive underneath.
  6. Motherboard Removal, Separate the bottom-right corner adhesive: passo 6, immagine 1 di 3 Motherboard Removal, Separate the bottom-right corner adhesive: passo 6, immagine 2 di 3 Motherboard Removal, Separate the bottom-right corner adhesive: passo 6, immagine 3 di 3
    • Rotate the opening pick around the bottom-right corner of the device.
  7. Motherboard Removal, Separate the right adhesive: passo 7, immagine 1 di 3 Motherboard Removal, Separate the right adhesive: passo 7, immagine 2 di 3 Motherboard Removal, Separate the right adhesive: passo 7, immagine 3 di 3
    • Don't insert the pick more than 3 mm to avoid damaging the components along the right edge.
    • Slide the new pick along the right edge of the device towards the top-right corner.
  8. Motherboard Removal, Heat the top edge: passo 8, immagine 1 di 1
    • Apply a heated iOpener to the top edge of the device to loosen the adhesive underneath.
  9. Motherboard Removal, Separate the top-right corner adhesive: passo 9, immagine 1 di 3 Motherboard Removal, Separate the top-right corner adhesive: passo 9, immagine 2 di 3 Motherboard Removal, Separate the top-right corner adhesive: passo 9, immagine 3 di 3
    • Rotate the opening pick around the top-right corner of the device.
  10. Motherboard Removal, Separate the top adhesive: passo 10, immagine 1 di 3 Motherboard Removal, Separate the top adhesive: passo 10, immagine 2 di 3 Motherboard Removal, Separate the top adhesive: passo 10, immagine 3 di 3
    • Slide the new pick along the top edge of the device towards the top-left corner.
  11. Motherboard Removal, Heat the left edge: passo 11, immagine 1 di 1
    • Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
  12. Motherboard Removal, Separate the top-left corner adhesive: passo 12, immagine 1 di 3 Motherboard Removal, Separate the top-left corner adhesive: passo 12, immagine 2 di 3 Motherboard Removal, Separate the top-left corner adhesive: passo 12, immagine 3 di 3
    • Rotate the opening pick around the top-left corner of the device.
  13. Motherboard Removal, Separate the left adhesive: passo 13, immagine 1 di 3 Motherboard Removal, Separate the left adhesive: passo 13, immagine 2 di 3 Motherboard Removal, Separate the left adhesive: passo 13, immagine 3 di 3
    • Slide the new pick along the left edge of the device towards the bottom-left corner.
  14. Motherboard Removal, Separate the bottom-left corner adhesive: passo 14, immagine 1 di 3 Motherboard Removal, Separate the bottom-left corner adhesive: passo 14, immagine 2 di 3 Motherboard Removal, Separate the bottom-left corner adhesive: passo 14, immagine 3 di 3
    • Rotate the opening pick around the bottom-left corner of the device.
    • At this point, the perimeter of the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
  15. Motherboard Removal, Remove the screen: passo 15, immagine 1 di 3 Motherboard Removal, Remove the screen: passo 15, immagine 2 di 3 Motherboard Removal, Remove the screen: passo 15, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the top of the device facing you, pull the screen up and away from you like you're opening a book.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
    • During reassembly:
    • This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
  16. Motherboard Removal, Disconnect the display cable: passo 16, immagine 1 di 2 Motherboard Removal, Disconnect the display cable: passo 16, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Motherboard Removal: passo 17, immagine 1 di 2 Motherboard Removal: passo 17, immagine 2 di 2
    • Use tweezers, or you fingers, to hold the display cable in place.
    • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor's press connector attached to the display cable.
    • Take note of the display cable's position; you will need to bend it in the same way when connecting a new screen.
  18. Motherboard Removal, Remove the screen: passo 18, immagine 1 di 3 Motherboard Removal, Remove the screen: passo 18, immagine 2 di 3 Motherboard Removal, Remove the screen: passo 18, immagine 3 di 3
    • Remove the screen from the frame.
  19. Motherboard Removal, Unfasten the frame bracket: passo 19, immagine 1 di 3 Motherboard Removal, Unfasten the frame bracket: passo 19, immagine 2 di 3 Motherboard Removal, Unfasten the frame bracket: passo 19, immagine 3 di 3
    • Use a Phillips #00 screwdriver to remove the fifty 3 mm-long screws securing the frame bracket to the frame.
    • The third photo has the same screws marked by quadrant. Use this photo during reassembly to help account for all the screws:
    • Bottom left = 9 screws
    • Bottom right = 14 screws
    • Top right = 12 screws
    • Top left = 15 screws
  20. Motherboard Removal, Remove the frame bracket: passo 20, immagine 1 di 3 Motherboard Removal, Remove the frame bracket: passo 20, immagine 2 di 3 Motherboard Removal, Remove the frame bracket: passo 20, immagine 3 di 3
    • Lift the frame bracket away from the frame, making sure to thread the display cable through its socket.
  21. Motherboard Removal, Disconnect the battery: passo 21, immagine 1 di 2 Motherboard Removal, Disconnect the battery: passo 21, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the battery's press connector secured to the motherboard.
  22. Motherboard Removal, Disconnect the display cable: passo 22, immagine 1 di 3 Motherboard Removal, Disconnect the display cable: passo 22, immagine 2 di 3 Motherboard Removal, Disconnect the display cable: passo 22, immagine 3 di 3
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the motherboard.
    • Repeat for the fingerprint sensor cable attached to display cable.
  23. Motherboard Removal, Remove the display cable: passo 23, immagine 1 di 2 Motherboard Removal, Remove the display cable: passo 23, immagine 2 di 2
    • Use your fingers to remove the display cable.
  24. Motherboard Removal, Disconnect the daughterboard interconnect cable: passo 24, immagine 1 di 2 Motherboard Removal, Disconnect the daughterboard interconnect cable: passo 24, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the daughterboard interconnect cable's press connector secured to the motherboard.
  25. Motherboard Removal, Disconnect the keyboard dock port cable: passo 25, immagine 1 di 2 Motherboard Removal, Disconnect the keyboard dock port cable: passo 25, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the keyboard dock port cable's press connector secured to the motherboard.
  26. Motherboard Removal, Remove the front camera: passo 26, immagine 1 di 3 Motherboard Removal, Remove the front camera: passo 26, immagine 2 di 3 Motherboard Removal, Remove the front camera: passo 26, immagine 3 di 3
    • Use the flat end of a spudger to pry up and disconnect the front camera's press connector secured to the motherboard.
    • Use tweezers, or your fingers, to remove the front camera.
  27. Motherboard Removal, Disconnect the microSD card reader: passo 27, immagine 1 di 2 Motherboard Removal, Disconnect the microSD card reader: passo 27, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the microSD card reader's press connector secured to the motherboard.
  28. Motherboard Removal, Disconnect the rear camera: passo 28, immagine 1 di 3 Motherboard Removal, Disconnect the rear camera: passo 28, immagine 2 di 3 Motherboard Removal, Disconnect the rear camera: passo 28, immagine 3 di 3
    • Use the flat end of a spudger to pry up and disconnect the rear camera's two press connectors secured to the motherboard.
  29. Motherboard Removal, Disconnect the power button cable: passo 29, immagine 1 di 2 Motherboard Removal, Disconnect the power button cable: passo 29, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the power button cable's press connector secured to the motherboard.
  30. Motherboard Removal, Disconnect the bottom-right coaxial cable: passo 30, immagine 1 di 2 Motherboard Removal, Disconnect the bottom-right coaxial cable: passo 30, immagine 2 di 2
    • Use the point of a spudger to carefully pry up and disconnect the bottom-right loudspeaker's yellow coaxial cable from the motherboard.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  31. Motherboard Removal, Reposition the bottom-right coaxial cable: passo 31, immagine 1 di 3 Motherboard Removal, Reposition the bottom-right coaxial cable: passo 31, immagine 2 di 3 Motherboard Removal, Reposition the bottom-right coaxial cable: passo 31, immagine 3 di 3
    • Pull the coaxial cable away from the frame, making sure the cable is completely unthreaded from the motherboard.
  32. Motherboard Removal, Disconnect the interconnect cable: passo 32, immagine 1 di 2 Motherboard Removal, Disconnect the interconnect cable: passo 32, immagine 2 di 2
    • Use the flat end of a spudger to pry up and disconnect the interconnect cable's press connector secured to the motherboard.
  33. Motherboard Removal, Disconnect the top-right coaxial cable: passo 33, immagine 1 di 2 Motherboard Removal, Disconnect the top-right coaxial cable: passo 33, immagine 2 di 2
    • Use the point of a spudger to carefully pry up and disconnect the top-right loudspeaker's blue coaxial cable from the motherboard.
  34. Motherboard Removal, Unfasten the motherboard: passo 34, immagine 1 di 2 Motherboard Removal, Unfasten the motherboard: passo 34, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the three 2 mm screws securing the motherboard to the frame.
  35. Motherboard Removal, Remove the motherboard: passo 35, immagine 1 di 3 Motherboard Removal, Remove the motherboard: passo 35, immagine 2 di 3 Motherboard Removal, Remove the motherboard: passo 35, immagine 3 di 3
    • Insert a spudger into a gap between the motherboard and the frame.
    • Pry up with the spudger to release the motherboard from its clips.
    • Remove the motherboard.
    • During reassembly, refasten the motherboard screws first to properly align it into place, then reconnect the cables.
Conclusione
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Tab S7+ Answers community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
163.711 Reputazione
769 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.648 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 87
