Minolta Dimage Xt LCD Screen Disassembly
Introduzione
Vai al passo 1If you need to replace the LCD screen of your Minolta Dimage Xt, follow this guide. The LCD screen is held into the camera by the outer casing and an internal bracket. It is one component, so there isn't a way to just replace the LCD screen, without first removing other parts. Once screen is out of the bracket, wires must be removed to completely remove the LCD screen.
Before beginning this guide, be sure to remove the batteries from the camera.
Cosa ti serve
Then, carefully pry apart the front and back outer casing away from the internal components.
Lens cover can be accessed without removing rear housing. I was able to lift off the front to access the lens cover mechanism while leaving the rear in place.
The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
To install a new LCD screen you will have to reconnect the wires and properly place them in the bracket. Make sure to reattach the ribbon wire before finishing repairs.
Preparati per le riparazioni future
Acquista tutti
#000 bit seems to work better. There are seven screws in total (2 on either end and 3 on bottom).
Doug Ewing - Replica
