Salta al contenuto principale
Microsoft Surface Pro 2 LCD Display Replacement
Mathew B
Mathew B e 6 altri collaboratori
Ultimo aggiornamento il 3 mar 2025
10 - 20 minuti
Facile
Introduzione Migliore
Introduzione
Vai al passo 1
If your screen is unresponsive to touch, cracked, or flickering than placing your screen may solve these problems.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: passo 1, immagine 1 di 2 Microsoft Surface Pro 2 LCD Display Replacement, LCD Display: passo 1, immagine 2 di 2
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 LCD Display Replacement: passo 2, immagine 1 di 1
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 LCD Display Replacement: passo 3, immagine 1 di 1
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 LCD Display Replacement: passo 4, immagine 1 di 3 Microsoft Surface Pro 2 LCD Display Replacement: passo 4, immagine 2 di 3 Microsoft Surface Pro 2 LCD Display Replacement: passo 4, immagine 3 di 3
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
Conclusione
Altre 6 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Mathew B
Membro da: 09/19/16
323 Reputazione
2 Guide realizzate
USF Tampa, Team 6-2, Remmell Fall 2016 Membro di USF Tampa, Team 6-2, Remmell Fall 2016
USFT-REMMELL-F16S6G2
4 Membri
11 Guide realizzate
5Commenti sulla guida
After replacing the screen my surface will turn on but the screen is just black.... in device manager its showing up as a 'Digital Flat Panel'
yet the screen is still black.. faulty replacement panel???
austin jones - Replica
Same thing happening to me… :(
Marco - Replica
I did this procedure but i dont know why the display is not working it blink and then turnoff can somebody help me how to fix this problem
Smart Instruments - Replica
I purchased a screen replacement (LCD and Digitizer), but apparently, the flex from the motherboard to the screen (the small connector in red as well as the one on the lcd) are missing. Is there a way or place I can purchase just those flex? Or do I need to get a whole new motherboard?
Roselite - Replica
Myne doesn't boot. The display is dack nothing happens. It's like it's not charging. What do I do. Thanks
ARCHER TABULEY - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 38
Tutti i Tempi: 15,126
