Merch Source Projector Entertainment II Motherboard
Introduzione
Vai al passo 1Follow this guide to repair components on the logic board. All you will need a solder gun and steady hands.
Cosa ti serve
Strumenti
Mostra di più…
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
Once the ribbon cable is disengaged gently pull the cable off the motherboard.
Preparati per le riparazioni future
Acquista tutti3Commenti sulla guida
Was wondering if you could help me identify a microchip on the board by the speaker?
mine acts like it does not recognize the rca cords. help
