Salta al contenuto principale
Merch Source Projector Entertainment II Light Bulb Replacement
Stephanie
Stephanie e 8 altri collaboratori
Ultimo aggiornamento il 26 lug 2024
10 - 15 minuti
Facile
Immagini Non Adeguate
Prerequisiti Non Soddisfatti
Introduzione
Vai al passo 1
Dim picture? No display? Discolored output? No problem! Use this guide to replace the burnt light bulb with a new one. To complete this replacement, you will need the following parts ready:
Cosa ti serve
  1. Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: passo 1, immagine 1 di 2 Merch Source Projector Entertainment II Light Bulb Replacement, Outer Casing: passo 1, immagine 2 di 2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Merch Source Projector Entertainment II Light Bulb Replacement: passo 2, immagine 1 di 1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Merch Source Projector Entertainment II Light Bulb Replacement: passo 3, immagine 1 di 2 Merch Source Projector Entertainment II Light Bulb Replacement: passo 3, immagine 2 di 2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: passo 4, immagine 1 di 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: passo 4, immagine 2 di 3 Merch Source Projector Entertainment II Light Bulb Replacement, Remove light bulb assembly from housing unit: passo 4, immagine 3 di 3
    • Remove the light bulb from its housing unit.
    • Do not damage the 2 white cables leading into the light bulb panel.
  5. Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: passo 5, immagine 1 di 2 Merch Source Projector Entertainment II Light Bulb Replacement, Replace light bulb: passo 5, immagine 2 di 2
    • Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
    • The light blub is held into the socket with prongs, and should easily pull straight out.
    What light bulb do I need?
    ingadewitt606 - Replica
Conclusione
Stephanie
Membro da: 01/08/15
282 Reputazione
3 Guide realizzate
Cal Poly, Team 18-3, Maness Winter 2015 Membro di Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 Membri
4 Guide realizzate
1Commento della guida
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,157
