Salta al contenuto principale
Main Click Buttons
Main Click Buttons
Jerico Morales
Jerico Morales e 2 altri collaboratori
Ultimo aggiornamento il 10 dic 2022
5 - 7 minuti
Facile
Introduzione
Vai al passo 1
Use this guide to remove the black covers protecting the mouse's white click button pieces.
Cosa ti serve
Strumenti
  1. Main Click Buttons, Click Buttons: passo 1, immagine 1 di 2 Main Click Buttons, Click Buttons: passo 1, immagine 2 di 2
    • Use a blue spudger to pry all 4 mouse feet off the bottom of the mouse.
  2. Main Click Buttons: passo 2, immagine 1 di 2 Main Click Buttons: passo 2, immagine 2 di 2
    • Use a #00 screwdriver (3x5mm) to unscrew all 6 screws from under the mouse feet.
  3. Main Click Buttons: passo 3, immagine 1 di 2 Main Click Buttons: passo 3, immagine 2 di 2
    • Use a blue spudger to open the bottom battery port.
  4. Main Click Buttons: passo 4, immagine 1 di 2 Main Click Buttons: passo 4, immagine 2 di 2
    • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the internal hardware.
  5. Main Click Buttons: passo 5, immagine 1 di 3 Main Click Buttons: passo 5, immagine 2 di 3 Main Click Buttons: passo 5, immagine 3 di 3
    • Use pliers to grip and remove the black covers over the button — the black cover and the button, a small white plastic piece, should come off).
    That’s really mean. Some kid is going to do that, and not understand why the replacement switch won’t go on.
    JW Smythe - Replica
Conclusione
Altre 17 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
6Commenti sulla guida
how are you supposed to put the feet back?
Owen Yuen - Replica
you have to buy new ones… i’m more concerned of using pliers to take the switch apart, when ideally you should desolder it and replace it with a proper omron switch (not made in china)
Erick Alonso Duque -
He is only removing the cover, not the whole button. But doing it with pliers is skipping that it has two clips, one at each end and you could damage the board just twisting and pulling
Russell Reeling -
Are the side buttons the same?
S I - Replica
What do you do after step 5? And that copper spring looks wrong. It shouldn’t look like that. The correct positioning is this: https://community.pcgamingwiki.com/galle...
Nonalbert Noneinstein - Replica
The side buttons are the same - I just replaced an old and faulty left with a right one from another mouse. Now it works fine. It needs soldering. Repairing the spring inside the switch did not work for me (doesn't mean someone else can't do it).
Balázs Kiss - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 43
Ultimi 30 Giorni: 187
Tutti i Tempi: 22,996
