Main Click Buttons
Introduzione
Vai al passo 1Use this guide to remove the black covers protecting the mouse's white click button pieces.
Cosa ti serve
Strumenti
Use a blue spudger to pry all 4 mouse feet off the bottom of the mouse.
Altre 18 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti6Commenti sulla guida
you have to buy new ones… i’m more concerned of using pliers to take the switch apart, when ideally you should desolder it and replace it with a proper omron switch (not made in china)
He is only removing the cover, not the whole button. But doing it with pliers is skipping that it has two clips, one at each end and you could damage the board just twisting and pulling
What do you do after step 5? And that copper spring looks wrong. It shouldn’t look like that. The correct positioning is this: https://community.pcgamingwiki.com/galle...
The side buttons are the same - I just replaced an old and faulty left with a right one from another mouse. Now it works fine. It needs soldering. Repairing the spring inside the switch did not work for me (doesn't mean someone else can't do it).
