Salta al contenuto principale
Mac mini (PowerPC) RAM Replacement
iRobot
iRobot e 4 altri collaboratori
Ultimo aggiornamento il 2 set 2021
Nessuna stima
Moderato
Guida In Evidenza
Introduzione
Vai al passo 1
This machine uses full-size desktop RAM.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Mac mini (PowerPC) RAM Replacement, Top Housing: passo 1, immagine 1 di 2 Mac mini (PowerPC) RAM Replacement, Top Housing: passo 1, immagine 2 di 2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
    A spackle knife makes these steps go much faster.
    jouniseppanen - Replica
    A double sided letter opener or a thin non-serrated butter knife will suffice.
    To prenent cosmetic blemishes, place a matchbook cover or similar thin cardboard on the outer perimeter under the “jimmy”.
    Mike - Replica
    Despite mentioning recommended tools at the top I think it’s really worthwhile making a point about narrow Philips screwdrivers at this point before people start putting the case apart.
    Matt D - Replica
  2. Mac mini (PowerPC) RAM Replacement: passo 2, immagine 1 di 3 Mac mini (PowerPC) RAM Replacement: passo 2, immagine 2 di 3 Mac mini (PowerPC) RAM Replacement: passo 2, immagine 3 di 3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    Patience is your best friend.
    Do not insert “jimmy in too far. Marking a line from tip upwards on the tool will prevent too far insertion, possibly breaking tabs or damaging internal components.
    To prevent the cover closing back up, small strips of matchbook cover (os equivalent) can be inserted about half inch hold prevent closure.
    Mike - Replica
    I think it needs to be made more clear that what you want to be doing is applying upward pressure on the back I/O panel with your HAND while pressing the clips with the jimmy, sort of like tensioning a lock and then setting individual tumblers. (Yeah, I watch LockPickingLawyer.)
    The pictures appear to show trying to lift the lower housing using the jimmy, similar to how I've seen people doing things like prying with a putty knife or screwdriver... and that plastic is only going to get more brittle over time.
    If you apply the upward pressure with your hand via the back panel and then work your way around the outside edge clip-by-clip, then it's much easier to be gentle with the jimmy because your only goal is to press on each clip enough to release it. All the rest of the force comes from, say, a finger hooked into the edge of the Ethernet port and a thumb pressing on the edge of the top cover.
    ssokolow - Replica
  3. Mac mini (PowerPC) RAM Replacement: passo 3, immagine 1 di 2 Mac mini (PowerPC) RAM Replacement: passo 3, immagine 2 di 2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
  4. Mac mini (PowerPC) RAM Replacement: passo 4, immagine 1 di 2 Mac mini (PowerPC) RAM Replacement: passo 4, immagine 2 di 2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
  5. Mac mini (PowerPC) RAM Replacement: passo 5, immagine 1 di 2 Mac mini (PowerPC) RAM Replacement: passo 5, immagine 2 di 2
    • Keep working around the perimeter, freeing the clips along the final edge.
  6. Mac mini (PowerPC) RAM Replacement: passo 6, immagine 1 di 2 Mac mini (PowerPC) RAM Replacement: passo 6, immagine 2 di 2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
    Before reassembly, make sure no wires are sticking out.
    Line up top cover carefully. Gently press down on top cover until top and bottom fully seated.
    CAUTION! DO NOT PRESS TOO HARD ON THE COVER TO PREVENT CRACKING THE PLASTIC TOP.
    GO EASY.
    Mike - Replica
    Re: reassembly, I found it gentler to use the jimmy to lightly press the plastic clips in a little bit to get them past catching on the frame with minimal force.
    ssokolow - Replica
  7. Mac mini (PowerPC) RAM Replacement, Mass Storage Unit: passo 7, immagine 1 di 1
    • If your mini does not have Airport installed, then skip this step.
    • Grasp the Airport antenna board and lift it off of the two plastic posts holding it in place. You may need to push back the black plastic tab jutting through the lower left corner of the board.
  8. Mac mini (PowerPC) RAM Replacement: passo 8, immagine 1 di 1
    • Remove the yellow tape securing the power button cable to the black plastic framework.
  9. Mac mini (PowerPC) RAM Replacement: passo 9, immagine 1 di 1
    • Remove the three black Phillips screws securing the plastic framework to the logic board and lower case.
  10. Mac mini (PowerPC) RAM Replacement: passo 10, immagine 1 di 1
    • Grasp the optical drive and mass storage unit in one hand and lift up enough so that you can see beneath it.
    I just put in a 1G RAM chip that just came in the mail from iFixit. And though I followed every step this step (removing the HD, cooling fan, and drive unit) was not needed. I put the chip in, put everything back in place then removed and replaced the RAM with no problems. So it would seem that for a/my PowerPC Mac Mini (I have a 1.33 Ghz processor) it was not a needed step.
    mbob518 - Replica
    BTW, it took about 15 - 20 min even with my experimentation.
    Citazione da mbob518:
    mbob518 - Replica
  11. Mac mini (PowerPC) RAM Replacement: passo 11, immagine 1 di 1
    • If your mini has neither an Airport card nor a Bluetooth board, you can simply lift the optical drive up and away. Otherwise, you need to disconnect the Airport and/or Bluetooth antenna cables first.
    • With your free hand, pull the Bluetooth cable up from Bluetooth board and unplug the Airport antenna cable from the right of the Airport card. Caution: both of these connections are very small. When re-assembling unit after repair, you may want to remove the two screws holding the airport card to the assembly and lift the card up and out to re-attach the cables.
    havin a hard time with step 9. i don't really see how I'm supposed to remove the Wi-Fi/Bluetooth cables from the Airport card. They seem to be soldered in! is there a twisting motion involved? I just don't wanna mess it up more than i already did with my putty knife haha!
    chris - Replica
    Same problem here on this one. There seems to be no way to get them off and I can't seem to unscrew this thing. I think this otherwise great guide should be more precise about how to get the antenna cables out of the way :-(
    sebastian.patting - Replica
    Antenna cables just pop off - straight up.
    Must be perfectly aligned when reconnecting as well before you re-seat them.
    Small needle nose pliers may be useful or a spudger or flat jewelers screwdriver to pry up on the cable as close to the connector as possible.
    rockpiano54 - Replica
  12. Mac mini (PowerPC) RAM Replacement, RAM: passo 12, immagine 1 di 1
    • Pull back the black plastic latches on either end of the RAM chip.
  13. Mac mini (PowerPC) RAM Replacement: passo 13, immagine 1 di 1
    • Grasp the RAM chip at the end opposite of the back ports, and pull directly up.
Conclusione
Altre 80 persone hanno completato questa guida.
Documenti Allegati
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
2Commenti sulla guida
Many thanks for giving me the confidence to do this, and the images make it soooo much easier.
My comment is that on my A1103 with Airport (but without the module above the RAM),I didn't even need to remove the HDD/CD assembly, thus cutting down upgrade time considerably. I was pleased to note that RAM replacement did not require the RAM module to be angled forward/backward as on some main boards,
Peter Garner - Replica
Agreed. I didn't need to remove the assembly either. The RAM comes straight up.
Ryan Buckner -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 66
Tutti i Tempi: 82,166
