Salta al contenuto principale
MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement
Jordan Buck
Jordan Buck e 2 altri collaboratori
Ultimo aggiornamento il 17 giu 2020
20 - 30 minuti
Moderato
Introduzione
Vai al passo 1
This guide demonstrates how to replace the LCD screen in the MSI GP62MVR 6RF Leopard Pro laptop. It is a moderately difficult process with no special skills required. Avoid touching the circuitry when the screen is off to avoid short-circuiting components or shocking yourself. If the screen has odd pixels, discolored or incorrect textures, or fails to display anything at all, then the LCD screen will need to be replaced. Follow this guide to change the LCD screen in a MSI GP62MVR 6RF Leopard Pro.
Cosa ti serve
Strumenti
Mostra di più…
  1. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 2
    • Using the Jimmy tool, pry the front cover off at the seam.
    • The Jimmy tool is the utensil in the first picture in the user's hand.
  2. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: passo 2, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: passo 2, immagine 2 di 2
    • Remove the four 2 mm screws on the bottom and top corners of the screen using a Phillips #0 screwdriver.
  3. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: passo 3, immagine 1 di 1
    • Using the Jimmy, pry off the unscrewed LCD display.
    • Make sure the black adhesive is out of the way.
    • Don't pull the screen completely off, as the screen will still be attached.
  4. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: passo 4, immagine 1 di 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: passo 4, immagine 2 di 2
    • Remove the ribbon cable by pulling on the bar code tab.
Conclusione
3Commenti sulla guida
Hey Jordan, when reassembling the front cover (which in my case, a GP63 Leopard 8RE, is glued at the bottom) what type of glue should be used? Thanks
Jaime Blasco - Replica
Hi Jaime, two part expoxy (Alraldite) glue should work, otherwise 3M double-sided adhesive tape would work as well.
Jordan Buck -
Hi Jordan,
If the screen is damaged due to the cover itself being bent, do you have any advice?
Thanks
Ainsley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,602
