Salta al contenuto principale
Logic Board Connectors
Arthur Shi
Arthur Shi e 4 altri collaboratori
Ultimo aggiornamento il 7 mag 2024
Nessuna stima
Moderato
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Introduzione
Vai al passo 1
This is a prerequisite only guide. It disconnects most of the connectors and removes most of the screws to take the motherboard out. The shots are taken such that you can’t see whether the Taptic Engine is out or not.
Note that each iPhone's logic board and Touch ID fingerprint sensor are paired at the factory, so replacing the logic board will disable Touch ID unless you also install a replacement home button that has been properly paired to your new logic board.
Opening the iPhone 8 will damage the waterproof seals on the display. If you do not replace the adhesive seals, your phone will function normally, but will no longer be water-resistant.
Cosa ti serve
Strumenti
Mostra di più…
  1. Logic Board Connectors, Disconnect the logic board: passo 1, immagine 1 di 2 Logic Board Connectors, Disconnect the logic board: passo 1, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
  2. Logic Board Connectors: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm standoff screw
    • One 3.1 mm Phillips screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  3. Logic Board Connectors: passo 3, immagine 1 di 1
    • Remove the rear-facing camera bracket.
  4. Logic Board Connectors: passo 4, immagine 1 di 2 Logic Board Connectors: passo 4, immagine 2 di 2
    • Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up.
  5. Logic Board Connectors: passo 5, immagine 1 di 1
    • Remove the two screws securing the upper cable bracket:
    • One 2.9 mm Phillips screw
    • One 1.3 mm Phillips screw
  6. Logic Board Connectors: passo 6, immagine 1 di 1
    • Remove the upper cable bracket.
  7. Logic Board Connectors: passo 7, immagine 1 di 2 Logic Board Connectors: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to pry the upper cable connector up from its socket.
  8. Logic Board Connectors, Remove the top left antenna component: passo 8, immagine 1 di 1
    • Remove the three Phillips 1.3 mm screws securing the top left antenna component.
  9. Logic Board Connectors: passo 9, immagine 1 di 1
    • Remove the 1.4 mm Phillips screw securing the antenna component to the top of edge of the case.
  10. Logic Board Connectors: passo 10, immagine 1 di 1
    • Remove the antenna component.
  11. Logic Board Connectors, Remove the top left grounding clip: passo 11, immagine 1 di 1
    • Remove the two Phillips screws securing the grounding clip at the top left edge of the logic board:
    • One 1.5 mm Phillips screw
    • One 2.6 mm Phillips screw
  12. Logic Board Connectors: passo 12, immagine 1 di 1
    • Remove the grounding clip.
  13. Logic Board Connectors, Unscrew the logic board: passo 13, immagine 1 di 1
    • Remove the three screws securing the motherboard:
    • One 1.8 mm Phillips screw
    • One 2.5 mm standoff screw
    • One 2.2 mm standoff screw
  14. Logic Board Connectors: passo 14, immagine 1 di 2 Logic Board Connectors: passo 14, immagine 2 di 2
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  15. Logic Board Connectors: passo 15, immagine 1 di 2 Logic Board Connectors: passo 15, immagine 2 di 2
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
Conclusione
Arthur Shi
Membro da: 01/03/18
287.505 Reputazione
595 Guide realizzate
iFixit Membro di iFixit
Staff
120 Membri
20.835 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 254
