Salta al contenuto principale
LisaTerminal with Linux/UNIX(Mac)
Cosa ti serve
  1. LisaTerminal with Linux/UNIX(Mac), On Linux: passo 1, immagine 1 di 1
    • In Terminal type: sudo apt-get install screen
    • sudo screen /dev/ttyUSB0 9600
    • Press ⌃A ⇧ : (at the same time). Once you see a : prompt at the bottom of the screen type
    • exec ::: /sbin/agetty -L -n 9600 ttyUSB0 vt100
    • Press return a few times on the Lisa keyboard and the login prompt should appear.
  2. LisaTerminal with Linux/UNIX(Mac), On macOS: passo 2, immagine 1 di 1
    • Type: ls /dev/cu.*
    • Copy the result that mentions USB
    • Then type the following replacing serial with the previous result: screen /dev/serial 9600
    • Press ⌃A ⇧:
    • When the : prompt appears type
    • exec ::: /usr/libexec/getty std.9600
    • Open LisaTerminal and set the settings to baud rate 9600 and set serial port to A.
    • Plug the serial cable into serial port A.
    • In MacWorks Plus and Macintosh System 6, the application Mac240 supports graphics and is generally fantastic for this type of connection.
    • Mac240 can be acquired from Macintosh Garden.
  3. LisaTerminal with Linux/UNIX(Mac), Uses: passo 4, immagine 1 di 1
    • This was done so I could use mutt for email and w3m for web browsing
    • mpg123 is great for music if your connected computer has speakers.
Linea Traguardo
LisaGuide
Membro da: 12/30/18
1.833 Reputazione
11 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 754
