Salta al contenuto principale
Linksys WAP54g Top Casing Replacement
Derek Myers
Derek Myers e 5 altri collaboratori
Ultimo aggiornamento il January 27, 2023
5 - 10 minuti
Facile
Prerequisite Mancanti
Introduzione
Vai al passo 1
In this guide we will go over removing the top casing.
Cosa ti serve
Strumenti
  1. Linksys WAP54g Top Casing Replacement, Top Casing: passo 1, immagine 1 di 1
    • Power down and unplug the device.
  2. Linksys WAP54g Top Casing Replacement: passo 2, immagine 1 di 1
  3. Linksys WAP54g Top Casing Replacement: passo 3, immagine 1 di 1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g Top Casing Replacement: passo 4, immagine 1 di 1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g Top Casing Replacement: passo 5, immagine 1 di 1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g Top Casing Replacement: passo 6, immagine 1 di 1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g Top Casing Replacement: passo 7, immagine 1 di 2 Linksys WAP54g Top Casing Replacement: passo 7, immagine 2 di 2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g Top Casing Replacement: passo 8, immagine 1 di 2 Linksys WAP54g Top Casing Replacement: passo 8, immagine 2 di 2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
Conclusione
From here you can take apart the rest of the router apart by following subsequent guides.
Derek Myers
Membro da: 10/04/11
288 Reputazione
5 Guide realizzate
Cal Poly, Team 21-21, Maness Fall 2011 Membro di Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Membri
12 Guide realizzate
1Commento della guida
Bon Tutoriel. Simple, mais les plastiques sont solidement attacher. Il faut donc forcer pour démonter la partie bleu. Mais c’est possible.
Merci.
Philippe Gabriel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,539
