Lenovo Yoga 910-13IKB SSD Replacement
Introduzione
Vai al passo 1Boot time and the amount of time it takes for the device to read and write information are directly related to the storage in your device. Over time, this storage can become slow; in extreme cases, it can become corrupted. In addition, it is also possible that the amount of storage your device has isn’t enough for your needs, so you might wish to replace it with a larger capacity drive. For those looking to replace or upgrade the storage on their Lenovo Yoga 910-13IKB, Lenovo has made it simple; this replacement requires only a JIS #00 screwdriver.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
Remove the panel.
Remove all 4 screws attached to SSD stick with a small Phillips head screwdriver.
Pull the SSD stick directly to the right until it shifts out of place to remove it.
The storage chip above it (further away from you) may also simply be detached by pulling it directly to the right until it clicks out.
Remove all 4 screws attached to both fans, and the back connector strip (long metal piece furthest from you with screws in it) with a small Phillips head screwdriver
Remove the back connector strip using a wedge device to pry it off of the device
With the back connector strip removed, pry the fans (which are attached) using a wedge device and the fans will now be maintainable.
1Commento della guida
Just one question: if I want to replace just the SSD, surely one goes straight from step one to step seven?
