Lenovo V14-IIL Camera Replacement
Introduzione
Vai al passo 1Impact damage, closing the laptop with excessive force, and scratches on the camera lens can cause the camera to break or develop bad image quality. This guide shows how to replace the camera within the Lenovo V14-IIL laptop. Be sure to remove small parts carefully.
Before using this guide, make sure to review the Lenovo V14-IIL troubleshooting page to review if there may be a solution that does not require component replacement.
Make sure to power off your laptop completely and disconnect from any external power source before beginning the process.
Cosa ti serve
Strumenti
Mostra di più…
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
Slide the cable hinge cover to the right.
Pull the part away from the screen.
