Salta al contenuto principale
Lenovo Thinkpad E540 WiFi Card Replacement
Timothy Sumner
Timothy Sumner e 4 altri collaboratori
Ultimo aggiornamento il June 21, 2018
5 - 10 minuti
Facile
Introduzione
Vai al passo 1
Are you experiencing difficulty connecting to the internet? Try replacing your WiFi card. This guide can help.
Cosa ti serve
Strumenti
  1. Lenovo Thinkpad E540 WiFi Card Replacement, Battery: passo 1, immagine 1 di 2 Lenovo Thinkpad E540 WiFi Card Replacement, Battery: passo 1, immagine 2 di 2
    • Push the battery release switches away from each other.
  2. Lenovo Thinkpad E540 WiFi Card Replacement: passo 2, immagine 1 di 1
    • Remove the battery.
  3. Lenovo Thinkpad E540 WiFi Card Replacement, WiFi Card: passo 3, immagine 1 di 1
    • Remove the single 1mm Phillips #0 screw holding the small plastic panel in place.
    For me a Phillips #1 was the first bit with a tight fit (testet PH #00, #0, #1).
    Till - Replica
  4. Lenovo Thinkpad E540 WiFi Card Replacement: passo 4, immagine 1 di 1
    • Use a plastic opening tool to remove panel.
  5. Lenovo Thinkpad E540 WiFi Card Replacement: passo 5, immagine 1 di 2 Lenovo Thinkpad E540 WiFi Card Replacement: passo 5, immagine 2 di 2
    • Disconnect the two antenna cables from the wifi card.
    • Remove the single 1mm Phillips #0 screw from the wifi card.
  6. Lenovo Thinkpad E540 WiFi Card Replacement: passo 6, immagine 1 di 1
    • Remove the wifi card by sliding it out.
Conclusione
Altre 3 persone hanno completato questa guida.
Timothy Sumner
Membro da: 02/14/18
1.052 Reputazione
8 Guide realizzate
USF Tampa, Team S2-G5, Nance Spring 2018 Membro di USF Tampa, Team S2-G5, Nance Spring 2018
USFT-NANCE-S18S2G5
4 Membri
8 Guide realizzate
2 Commenti
Pictures show battery is still connected to laptop.
Monte Christo - Replica
There appear to be several different wifi cards available, with different PN numbers. Is it necessary to replace with the exact same PN number? Can these wifi cards be upgraded?
Thomas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,196
