Salta al contenuto principale
Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement
Taylor Morgan
Taylor Morgan e 7 altri collaboratori
Ultimo aggiornamento il January 5, 2024
10 minuti
Moderato
Introduzione
Vai al passo 1
The 6th generation Lenovo ThinkPad X1 Yoga is a versatile 2-in-1 laptop launched in 2021. It is a top-notch choice for daily use, whether for work or academics and offers exceptional value for money. Nevertheless, specific laptop components can deteriorate over time, leading to issues. Suppose your laptop is slowing down, having trouble rebooting, or encountering corrupted files. In that case, it might point to a failing SSD. In such a scenario, you can use this guide to replace the SSD in your 6th Gen ThinkPad X1 Yoga in three simple steps.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
Mostra di più…
  1. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: passo 1, immagine 1 di 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: passo 1, immagine 2 di 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, Base Panel: passo 1, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the five 5 mm screws that secure the base panel.
    • Wedge a spudger between the base panel and chassis, and pry around the entire perimeter until you hear a pop and the base panel releases.
    • Lift the base panel up and off of the chassis.
  2. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: passo 2, immagine 1 di 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: passo 2, immagine 2 di 3 Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement, SSD: passo 2, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the two 2.2 mm screws securing the copper plate over the SSD.
    • Lift the copper plate up and out.
  3. Lenovo ThinkPad X1 Yoga (6th Gen) SSD Replacement: passo 3, immagine 1 di 1
    • Gently lift up on the left side of the SSD, then pull it to the left to remove it from its socket.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 50
Tutti i Tempi: 1,643
