Lamp Pull Chain Replacement
Introduzione
Vai al passo 1Have you ever had a lamp's pull chain break on you, leaving you with no way to turn it on? We understand. That's why we made this guide to fix the on/off switch on a perfectly good lamp! This guide will help you in repairing a snapped ball chain, allowing you to, once again, turn your lamp on and then off again.
Unplug the broken lamp and ensure you have all of the parts necessary for the repair.
Connect the chain with the chain connector to the broken chain on the lamp base.
What if the spring inside needs readjustment?
How is the internal parts that the chain is connected to assembled?
I have a situation like that that I'm currently trying to figure out.
Congratulations on fixing your lamp!
Altre 5 persone hanno completato questa guida.
4Commenti sulla guida
You saved my lamp! Thank you for this simple to follow guide.
All well and good, but isn’t it more likely that the break will be in the string which runs from the chain into the switch? This can be fixed by disassembling the switch itself - but where can one buy the right string?
On my lamp, the problem was not the chain but in the switch itself. This made it necessary to replace the entire socket since the switch was riveted to its base. I made this video which shows how to replace the socket and switch:https://youtu.be/0fLnUPWzLeI
Excellent, Thank you!
