Salta al contenuto principale
LG Refrigerator Compressor Run Capacitor Replacement
Cosa ti serve
    1. LG Refrigerator Compressor Run Capacitor Replacement, Unplug your refrigerator: passo 1, immagine 1 di 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser fan motor
      • Compressor motor and thermal overload device
      • Water supply valve assembly
      Chiedi a FixBot
      Aggiungi Commento
    1. LG Refrigerator Compressor Run Capacitor Replacement, Unfasten the control board cover: passo 2, immagine 1 di 1
      • Use a Phillips screwdriver to remove the screws securing the control board cover.
      Chiedi a FixBot
      Aggiungi Commento
    2. LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: passo 3, immagine 1 di 3 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: passo 3, immagine 2 di 3 LG Refrigerator Compressor Run Capacitor Replacement, Remove the control board cover: passo 3, immagine 3 di 3
      • Tilt the top edge of the cover toward you and lift it off.
      Chiedi a FixBot
      Aggiungi Commento
    1. LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: passo 4, immagine 1 di 3 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: passo 4, immagine 2 di 3 LG Refrigerator Compressor Run Capacitor Replacement, Unclip the capacitor: passo 4, immagine 3 di 3
      • Pull the left edge of the capacitor toward you to unclip it.
      • Handle the capacitor carefully as it may still be charged, and can give a dangerous and painful electrical shock. Avoid touching the terminals with your fingers or hands.
      • For information on capacitor safety, click here.
      Chiedi a FixBot
      Aggiungi Commento
    2. LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: passo 5, immagine 1 di 3 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: passo 5, immagine 2 di 3 LG Refrigerator Compressor Run Capacitor Replacement, Disconnect the capacitor: passo 5, immagine 3 di 3
      • Pull the connector straight off the capacitor to disconnect it.
      • Remove the capacitor.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
Membro da: 06/30/22
40.168 Reputazione
261 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
50.294 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 32
Ultimi 30 giorni: 139
Tutti i Tempi: 3,384
