Salta al contenuto principale
LG G3 Battery Replacement
Cosa ti serve
  1. LG G3 Battery Replacement, Back Cover: passo 1, immagine 1 di 2 LG G3 Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG G3 Battery Replacement: passo 2, immagine 1 di 2 LG G3 Battery Replacement: passo 2, immagine 2 di 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG G3 Battery Replacement, Battery: passo 3, immagine 1 di 2 LG G3 Battery Replacement, Battery: passo 3, immagine 2 di 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG G3 Battery Replacement: passo 4, immagine 1 di 2 LG G3 Battery Replacement: passo 4, immagine 2 di 2
    • Lift the battery out of its recess and remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Altre 21 persone hanno completato questa guida.
1Commento della guida
Thank you very much!
ItayDigital - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 12
Ultimi 7 giorni: 25
Ultimi 30 giorni: 77
Tutti i Tempi: 18,790
