Salta al contenuto principale
Joy-Con 2 (Right) Joystick Replacement
Cosa ti serve
  1. Joy-Con 2 (Right) Joystick Replacement, Remove the left edge screws: passo 1, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Remove the left edge screws: passo 1, immagine 2 di 2
    • Use a tri-point Y00 driver to remove the two 3.1 mm‑long black screws on the left edge of the controller.
  2. Joy-Con 2 (Right) Joystick Replacement, Insert an opening pick: passo 2, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Insert an opening pick: passo 2, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Insert an opening pick: passo 2, immagine 3 di 3
    • Insert an opening pick into the gap underneath the bumper button on the right side of the controller, with a point of the pick pointing downwards.
    • Pry up to slightly lift the plastic strip running across the right edge of the controller.
    • Slide the opening pick around to the front of the controller.
  3. Joy-Con 2 (Right) Joystick Replacement, Separate the plastic strip: passo 3, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Separate the plastic strip: passo 3, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Separate the plastic strip: passo 3, immagine 3 di 3
    • Slide the opening pick down the plastic strip to separate the clips and adhesive securing it to the controller's body.
  4. Joy-Con 2 (Right) Joystick Replacement, Remove the plastic strip: passo 4, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Remove the plastic strip: passo 4, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Remove the plastic strip: passo 4, immagine 3 di 3
    • Pry up on the bottom edge of the plastic strip with slow, steady force.
    • Repeat this prying action along the length of the strip until it's fully detached.
  5. Joy-Con 2 (Right) Joystick Replacement: passo 5, immagine 1 di 1
    • Remove the plastic strip.
  6. Joy-Con 2 (Right) Joystick Replacement, Remove the right edge screws: passo 6, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Remove the right edge screws: passo 6, immagine 2 di 2
    • Remove the two screws on the right edge of the controller:
    • One 3.1 mm‑long tri-point Y00 black screw
    • One 3.0 mm‑long JIS 00 silver screw
    • You can use a Phillips screwdriver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they're the same size.
  7. Joy-Con 2 (Right) Joystick Replacement, Insert an opening pick: passo 7, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Insert an opening pick: passo 7, immagine 2 di 2
    • Don't try to remove the back cover yet.
    • Insert an opening pick into the gap between the front and back halves of the controller on its right side.
    • Slide the pick down the controller to disengage the clips.
    • Leave the opening pick at the bottom of the controller's right edge, just before its curve.
    • The opening pick will fall out once the back cover is removed. If it falls out before then, put it back to keep the two halves separated.
  8. Joy-Con 2 (Right) Joystick Replacement, Insert a second opening pick: passo 8, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Insert a second opening pick: passo 8, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Insert a second opening pick: passo 8, immagine 3 di 3
    • Hold the controller upside-down.
    • Insert a point of another opening pick next to the release button towards the top of the controller.
    • Use the opening pick to press the release button through the gap.
  9. Joy-Con 2 (Right) Joystick Replacement, Release the back cover: passo 9, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Release the back cover: passo 9, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Release the back cover: passo 9, immagine 3 di 3
    • The back cover is connected to the controller by a cable at the bottom. Don't try to remove it completely yet.
    • While holding the release button with the opening pick, use your other hand to slide the back cover down to release the clips securing it to the controller's body.
    • Open the back cover.
  10. Joy-Con 2 (Right) Joystick Replacement, Remove the back cover: passo 10, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Remove the back cover: passo 10, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Remove the back cover: passo 10, immagine 3 di 3
    • Firmly grasp the two wires (yellow and white) above the rumble motor connector, located at the bottom of the controller's board, and pull the beige connector out of its socket.
    • Pulling the cable won't damage it, but don't dig your nails into the plastic sheathing.
    • Remove the back cover.
  11. Joy-Con 2 (Right) Joystick Replacement, Disconnect the battery: passo 11, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Disconnect the battery: passo 11, immagine 2 di 2
    • Use tweezers or your fingers to firmly grip the battery cable's white JST connector and pull straight away from its socket to disconnect it.
    • Once partially lifted, reposition your fingers/tweezers to beneath the connector's upper lip to increase your grip.
  12. Joy-Con 2 (Right) Joystick Replacement, Remove the trigger: passo 12, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Remove the trigger: passo 12, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Remove the trigger: passo 12, immagine 3 di 3
    • If your JIS 00 driver is able to access the screw underneath the trigger button, you may skip this step.
    • Insert an opening pick between the bumper (R) and trigger (ZR) buttons at the top of the controller.
    • Use the opening pick to pry the trigger away from the bumper until it pops off the controller.
    • You can lightly hold the ZR button with your finger to avoid launching it.
  13. Joy-Con 2 (Right) Joystick Replacement, Remove the release button: passo 13, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Remove the release button: passo 13, immagine 2 di 2
    • Pick up the release button and remove it.
  14. Joy-Con 2 (Right) Joystick Replacement, Remove the screws: passo 14, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Remove the screws: passo 14, immagine 2 di 2
    • Use a JIS 00 driver to remove the five screws securing the midframe:
    • Four 3.9 mm‑long silver screws
    • One 6.2 mm‑long black screw
  15. Joy-Con 2 (Right) Joystick Replacement, Remove the bumper: passo 15, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Remove the bumper: passo 15, immagine 2 di 2
    • Hold the midframe lightly in place.
    • Pull the bumper (R) button off its mounting pegs and remove it.
    • The midframe will lift slightly when removing this button.
  16. Joy-Con 2 (Right) Joystick Replacement, Remove the bracket: passo 16, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Remove the bracket: passo 16, immagine 2 di 2
    • Pick up the release button mounting bracket and remove it.
  17. Joy-Con 2 (Right) Joystick Replacement, Prop up the controller: passo 17, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Prop up the controller: passo 17, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Prop up the controller: passo 17, immagine 3 di 3
    • Use the back cover to prop up the controller while you work.
    • The buttons on the front of the controller should rest on the back cover's lip to keep it stable.
  18. Joy-Con 2 (Right) Joystick Replacement, Reposition the midframe: passo 18, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Reposition the midframe: passo 18, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Reposition the midframe: passo 18, immagine 3 di 3
    • Flip the controller's mid-frame over so it rests on the Joy-Con's inner edge (the edge with the shoulder buttons).
  19. Joy-Con 2 (Right) Joystick Replacement, Disconnect the midframe: passo 19, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Disconnect the midframe: passo 19, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Disconnect the midframe: passo 19, immagine 3 di 3
    • Use the point of a spudger to flip up the locking flap on the midframe cable ZIF connector, located on the controller's board.
  20. Joy-Con 2 (Right) Joystick Replacement: passo 20, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement: passo 20, immagine 2 di 2
    • Use tweezers or your fingers to gently pull the cable out of its socket.
  21. Joy-Con 2 (Right) Joystick Replacement, Remove the midframe: passo 21, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Remove the midframe: passo 21, immagine 2 di 2
    • Pick up and remove the midframe.
  22. Joy-Con 2 (Right) Joystick Replacement, Disconnect the board: passo 22, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Disconnect the board: passo 22, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Disconnect the board: passo 22, immagine 3 di 3
    • Repeat this procedure to disconnect the remaining three ZIF connectors on the controller's board.
  23. Joy-Con 2 (Right) Joystick Replacement, Remove the board screws: passo 23, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Remove the board screws: passo 23, immagine 2 di 2
    • Use a JIS 00 driver to remove the five 3.1 mm‑long black screws securing the board to the controller.
  24. Joy-Con 2 (Right) Joystick Replacement, Lift the board: passo 24, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Lift the board: passo 24, immagine 2 di 2
    • Insert the point of a spudger between the board and the controller, near the battery connector socket.
    • Pry up on the board enough to grasp its edge with your fingertips.
  25. Joy-Con 2 (Right) Joystick Replacement, Remove the board: passo 25, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Remove the board: passo 25, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Remove the board: passo 25, immagine 3 di 3
    • Lift the board by its outer edges to a roughly 45-degree angle, so it's no longer being blocked by the joystick assembly.
    • Make sure the black tape is fully lifted off the back of the joystick module. Work slowly to avoid tearing the tape.
    • Remove the board.
  26. Joy-Con 2 (Right) Joystick Replacement, Remove the joystick: passo 26, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Remove the joystick: passo 26, immagine 2 di 2
    • Use a JIS 00 driver to remove the two 3.9 mm‑long silver screws securing the joystick.
  27. Joy-Con 2 (Right) Joystick Replacement: passo 27, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement: passo 27, immagine 2 di 2
    • Pick up and remove the joystick.
  28. Joy-Con 2 (Right) Joystick Replacement, Disassembly complete: passo 28, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
  29. Joy-Con 2 (Right) Joystick Replacement, Install the joystick: passo 29, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Install the joystick: passo 29, immagine 2 di 2
    • Align the cut-out in the joystick's plastic frame with its peg on the controller.
    • Set the joystick in the controller. Gently wiggle the joystick to ensure it's fully seated.
  30. Joy-Con 2 (Right) Joystick Replacement: passo 30, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement: passo 30, immagine 2 di 2
    • Use a JIS 00 driver to install the two 3.9 mm‑long silver screws securing the joystick.
  31. Joy-Con 2 (Right) Joystick Replacement, Install the board: passo 31, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Install the board: passo 31, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Install the board: passo 31, immagine 3 di 3
    • Lower the board's flat side into the controller at an angle.
    • Use a spudger to bend the joystick's ribbon cable so it's perpendicular with the joystick.
    • Lower the board so the joystick's ribbon cable routes through the joystick cut-out in the board. Ensure the board is sitting underneath the locking tab on the frame.
  32. Joy-Con 2 (Right) Joystick Replacement: passo 32, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement: passo 32, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement: passo 32, immagine 3 di 3
    • Push the board towards the controller's inner edge (the side with the shoulder buttons) to prevent it from colliding with the joystick module.
    • Lower the board into the frame.
    • Use your finger or the flat end of a spudger to press the black tape onto the back of the joystick module.
  33. Joy-Con 2 (Right) Joystick Replacement: passo 33, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement: passo 33, immagine 2 di 2
    • Use a JIS 00 driver to install the five 3.1 mm‑long black screws securing the board to the controller.
  34. Joy-Con 2 (Right) Joystick Replacement, Connect the cables: passo 34, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Connect the cables: passo 34, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Connect the cables: passo 34, immagine 3 di 3
    • Make sure the locking flap is flipped up on the joystick cable ZIF connector.
    • Insert the joystick ribbon cable into its ZIF connector until it's fully seated.
    • The brown portion of the cable should end at the golden line on the board.
    • Use your finger or a spudger to flip the locking flap down to secure the cable.
  35. Joy-Con 2 (Right) Joystick Replacement: passo 35, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement: passo 35, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement: passo 35, immagine 3 di 3
    • Make sure the locking flap is flipped up on the Joy-Con connector cable ZIF connector.
    • Insert the Joy-Con connector ribbon cable into its ZIF connector until it's fully seated.
  36. Joy-Con 2 (Right) Joystick Replacement: passo 36, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement: passo 36, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement: passo 36, immagine 3 di 3
    • Repeat this procedure for the shoulder button ZIF connector. The cable is fully seated when its brown "wings" are in their slots on both sides of the connector.
    • This connector can be tricky—you may need to hold the flap open, or hold the cable in place when closing the flap.
  37. Joy-Con 2 (Right) Joystick Replacement, Connect the midframe: passo 37, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Connect the midframe: passo 37, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Connect the midframe: passo 37, immagine 3 di 3
    • Make sure the locking flap is flipped up on the midframe cable ZIF connector.
    • Reposition the midframe so its ribbon cable is aligned with its socket on the board.
    • Push the ribbon cable into its connector by moving the midframe. If needed, use tweezers to fully seat the cable. The darker brown tab at the tip of the cable should end at the golden line on the board.
  38. Joy-Con 2 (Right) Joystick Replacement, Install the bumper: passo 38, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Install the bumper: passo 38, immagine 2 di 2
    • Align the two springs on the bumper with their two posts on the midframe, and press it into place.
    • The bumper is held in place by the front shell of the controller. If it falls out, ensure it is fully seated in the shell.
  39. Joy-Con 2 (Right) Joystick Replacement, Install the midframe screws: passo 39, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Install the midframe screws: passo 39, immagine 2 di 2
    • Use a JIS 00 driver to install the three 3.9 mm‑long silver screws securing the midframe.
  40. Joy-Con 2 (Right) Joystick Replacement, Install the bracket: passo 40, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Install the bracket: passo 40, immagine 2 di 2
    • Align the release button mounting bracket with its screw holes and press it in the frame so it snaps into place.
    • The corner with the protruding square should be facing the battery.
  41. Joy-Con 2 (Right) Joystick Replacement: passo 41, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement: passo 41, immagine 2 di 2
    • Use a JIS 00 driver to install the two screws securing the release button bracket.
    • One 3.9 mm‑long silver screw
  42. Joy-Con 2 (Right) Joystick Replacement, Install the buttons: passo 42, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Install the buttons: passo 42, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Install the buttons: passo 42, immagine 3 di 3
    • If you left the trigger button in place, skip this step.
    • Align the trigger button with the top of the controller, with the "ZR" engraving facing out.
    • Set the trigger button onto its metal spring. Ensure the legs of the spring are seated properly in their channels on the midframe.
    • Press firmly on the trigger button to snap it into place.
    • Check that the metal stabilizer didn't fall out of position. If it did, remove the trigger, place it back into position, and try again.
  43. Joy-Con 2 (Right) Joystick Replacement: passo 43, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement: passo 43, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement: passo 43, immagine 3 di 3
    • Hold the release button so its smooth face is perpendicular to the controller.
    • Insert the release button into its bracket.
    • If the release pin doesn't stick out of the controller when the button is pressed, the button isn't installed correctly. Re-insert or flip the button and try again.
  44. Joy-Con 2 (Right) Joystick Replacement, Connect the battery: passo 44, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Connect the battery: passo 44, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Connect the battery: passo 44, immagine 3 di 3
    • Align the battery connector with its socket on the board.
    • Press down on the connector until it's fully seated.
  45. Joy-Con 2 (Right) Joystick Replacement, Connect the rumble motor: passo 45, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Connect the rumble motor: passo 45, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Connect the rumble motor: passo 45, immagine 3 di 3
    • Align the rumble motor connector to its socket on the bottom edge of the board, and push down until it's fully seated to connect it.
  46. Joy-Con 2 (Right) Joystick Replacement, Install the back cover: passo 46, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Install the back cover: passo 46, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Install the back cover: passo 46, immagine 3 di 3
    • Use an opening pick to press and hold the release button.
    • Place the back cover over the controller body so the release button cutout is slightly below the release button.
    • The release button is held down when the release pin is protruding from the frame. If the release button falls out of position, put it back and try again.
    • Press and slide the back cover up until the cut-out for the release button is aligned with the button itself.
    • Ensure the rumble motor wires (yellow & white) are fully within the frame.
  47. Joy-Con 2 (Right) Joystick Replacement: passo 47, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement: passo 47, immagine 2 di 2
    • Remove the opening pick.
  48. Joy-Con 2 (Right) Joystick Replacement, Install the right edge screws: passo 48, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Install the right edge screws: passo 48, immagine 2 di 2
    • Install the two screws on the right edge of the controller:
  49. Joy-Con 2 (Right) Joystick Replacement, Install the plastic strip: passo 49, immagine 1 di 3 Joy-Con 2 (Right) Joystick Replacement, Install the plastic strip: passo 49, immagine 2 di 3 Joy-Con 2 (Right) Joystick Replacement, Install the plastic strip: passo 49, immagine 3 di 3
    • Align the clips on the plastic strip with their cut-outs on the right edge of the controller body.
    • Insert the clips on the bottom edge first, then insert the rest so the plastic strip sits flush.
  50. Joy-Con 2 (Right) Joystick Replacement, Install the left edge screws: passo 50, immagine 1 di 2 Joy-Con 2 (Right) Joystick Replacement, Install the left edge screws: passo 50, immagine 2 di 2
    • Use a tri-point Y00 driver to install the two 3.1 mm‑long black screws on the left edge of the controller.
Conclusione
You finished fixing your Joy-Con 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Joy-Con 2 Answers Community for help.
Nick Schultz
Membro da: 03/24/24
36.897 Reputazione
224 Guide realizzate
1Commento della guida
Hello Reader!
I recently broke my right Nintendo Switch 2 joy-con when it fell off of my bed, and the joystick stem just snapped completely off. I thought all hope was lost, but then I found this guide and bought a repair kit (with proper screwdrivers, pliers, sticks, and smudger; can literally get it off of Amazon, if not from this website).
The steps were super thorough, and the pictures were amazingly accurate. I am a 19-year-old with no mechanical or technological experience, yet I was able to completely repair my joy-con in around an hour (maybe less), and now I don't have to buy new ones!
Please follow this guide if you need to fix your joy-con!! It works!!
Josh Driver - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 26
Ultimi 7 Giorni: 128
Ultimi 30 Giorni: 646
Tutti i Tempi: 2,328
