JD Razor 2000 Handle Bar Replacement
Introduzione
Vai al passo 1The JD Razor 2000 scooter features two soft-grip handle bars that are each attached to the T-Bar by a fastening button as well as a continuous string with stoppers at each end. This guide will show how to replace a handle bar.
Cosa ti serve
Strumenti
Firmly hold the handle bar in place.
Grab with one hand the black removable tip of the handle bar and pull it out.
Pull out the end of the tied string through the removable tip.
Press down firmly on the golden fastening button located on the handle bar being replaced.
While still pressing down on the fastening button, slide the handle bar apart from the T Bar.
Altre 2 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
