Salta al contenuto principale
JBL Pulse 3 Speaker Replacement
Kaitlyn Greenfield
Kaitlyn Greenfield e un altro collaboratore
Ultimo aggiornamento il December 23, 2020
25 - 30 minuti
Moderato
Necessarie Più Immagini
Introduzione
Vai al passo 1
There are four speakers located on the base of the JBL Pulse 3 under the speaker grill.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. JBL Pulse 3 Speaker Replacement, Speaker Grill: passo 1, immagine 1 di 1
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 Speaker Replacement: passo 2, immagine 1 di 1
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 Speaker Replacement: passo 3, immagine 1 di 2 JBL Pulse 3 Speaker Replacement: passo 3, immagine 2 di 2
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 Speaker Replacement, Outside Casing: passo 5, immagine 1 di 2 JBL Pulse 3 Speaker Replacement, Outside Casing: passo 5, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
    #00 not required, successfully opened with PH#1
    Stephen Hoefler - Replica
  5. JBL Pulse 3 Speaker Replacement: passo 6, immagine 1 di 2 JBL Pulse 3 Speaker Replacement: passo 6, immagine 2 di 2
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
    Ca I Specifically buy the top ring
    Julian Cruz - Replica
    I've the same concern as the comment above, can I buy the top ring separately?
    Yousef - Replica
    Opening is not as simple as demonstrated in Step 6. I have followed everything through, am I missing something?
    Kusala Kumsinda - Replica
    Is there any other place to get this part? It doesnt ship to the UK
    Amelia - Replica
  6. JBL Pulse 3 Speaker Replacement: passo 7, immagine 1 di 2 JBL Pulse 3 Speaker Replacement: passo 7, immagine 2 di 2
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 Speaker Replacement: passo 8, immagine 1 di 1
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 Speaker Replacement: passo 9, immagine 1 di 2 JBL Pulse 3 Speaker Replacement: passo 9, immagine 2 di 2
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
    This phase could be difficult. Try to “twist” the speaker to have a little gap between both parts and insert gently a screwdriver or opening toile to spread the gap.
    Richard Devos - Replica
  9. JBL Pulse 3 Speaker Replacement: passo 10, immagine 1 di 2 JBL Pulse 3 Speaker Replacement: passo 10, immagine 2 di 2
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 Speaker Replacement: passo 11, immagine 1 di 1
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
  11. JBL Pulse 3 Speaker Replacement, LED Light Display: passo 12, immagine 1 di 3 JBL Pulse 3 Speaker Replacement, LED Light Display: passo 12, immagine 2 di 3 JBL Pulse 3 Speaker Replacement, LED Light Display: passo 12, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
    • Pull the LED light display off of the JBL Pulse 3 base.
  12. JBL Pulse 3 Speaker Replacement: passo 13, immagine 1 di 2 JBL Pulse 3 Speaker Replacement: passo 13, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to pull the five connections off of the LED light display.
    up to step 13, the battery replacement steps are the same.
    From step 14 the steps change.
    Very good instructions for changing the battery in the jbl pulse 3 can be found here:
    https://www.youtube.com/watch?v=MpznDgxg...
    Mike Miker - Replica
  13. JBL Pulse 3 Speaker Replacement, Motherboard: passo 14, immagine 1 di 2 JBL Pulse 3 Speaker Replacement, Motherboard: passo 14, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
  14. JBL Pulse 3 Speaker Replacement: passo 15, immagine 1 di 3 JBL Pulse 3 Speaker Replacement: passo 15, immagine 2 di 3 JBL Pulse 3 Speaker Replacement: passo 15, immagine 3 di 3
    • Pull out the motherboard slightly from the LED light display as shown. Using tweezers, unplug the three connections attached to the motherboard.
  15. JBL Pulse 3 Speaker Replacement: passo 16, immagine 1 di 1
    • Pull the rest of the motherboard out from the LED light display.
    • Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
    Hi Guys! Thanks a lot for the tutorial, but anyone knows where THIS BLACK WIRE IS CONNECTED at the base of the speaker? I accidentally remove it..
    caiopeluso - Replica
  16. JBL Pulse 3 Speaker Replacement, Speaker: passo 17, immagine 1 di 2 JBL Pulse 3 Speaker Replacement, Speaker: passo 17, immagine 2 di 2
    • Using a Phillips #2 screwdriver, remove the four 10mm screws on the corner of the speaker on the side of the base of the JBL Pulse 3.
  17. JBL Pulse 3 Speaker Replacement: passo 18, immagine 1 di 2 JBL Pulse 3 Speaker Replacement: passo 18, immagine 2 di 2
    • Pull out the speaker and cut the black and red wire with wire cutters. The speaker should now be removed from the JBL Pulse 3.
Conclusione
Note: To finish replacing the speaker, you must solder both wires back on to the new speaker.
2Commenti sulla guida
My speaker is making weird noises. It sounds like being crack. Do I need to replace the speaker or try to teardown to clean up the dust?
John - Replica
Hey Mates. Tell me please, somebody knows , the size of the replacement speaker and it fit from jbl charge 3 or some models? Thanks
Seven Nes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 49
Tutti i Tempi: 2,827
