Salta al contenuto principale
JBL Charge 5 Battery Replacement
Cosa ti serve
  1. JBL Charge 5 Battery Replacement, Pry up the fabric cover: passo 1, immagine 1 di 3 JBL Charge 5 Battery Replacement, Pry up the fabric cover: passo 1, immagine 2 di 3 JBL Charge 5 Battery Replacement, Pry up the fabric cover: passo 1, immagine 3 di 3
    • Before starting repairs, turn off your device and unplug any cables.
    • Depending on the model, some fabric covers are secured only by plastic clips, while others use both plastic clips and screws.
    • Begin prying only on the edge shown in the photos. Otherwise, you run the risk of damaging the fabric cover's clips if your model's cover is also secured with screws.
    • Insert the flat end of a metal spudger into the seam between the two halves of the fabric cover.
    • Push the spudger underneath the edge of the fabric cover without the textured rubber and pry upwards to release its plastic clips.
  2. JBL Charge 5 Battery Replacement, Release the plastic clips: passo 2, immagine 1 di 3 JBL Charge 5 Battery Replacement, Release the plastic clips: passo 2, immagine 2 di 3 JBL Charge 5 Battery Replacement, Release the plastic clips: passo 2, immagine 3 di 3
    • Repeat the previous step, using your spudger to work your way along the entire seam to release the remaining plastic clips.
  3. JBL Charge 5 Battery Replacement, Unfasten the fabric cover: passo 3, immagine 1 di 2 JBL Charge 5 Battery Replacement, Unfasten the fabric cover: passo 3, immagine 2 di 2
    • Use a Phillips screwdriver to remove the two 10.6 mm-long screws securing the fabric cover.
    • Don't try to fully remove the fabric cover just yet, as it‘s still held in place by more plastic clips.
  4. JBL Charge 5 Battery Replacement, Pry up the fabric cover's other side: passo 4, immagine 1 di 3 JBL Charge 5 Battery Replacement, Pry up the fabric cover's other side: passo 4, immagine 2 di 3 JBL Charge 5 Battery Replacement, Pry up the fabric cover's other side: passo 4, immagine 3 di 3
    • Use your metal spudger to pry up the other edge of the fabric cover—the side with the textured rubber—to release the remaining plastic clips.
  5. JBL Charge 5 Battery Replacement, Remove the fabric cover: passo 5, immagine 1 di 3 JBL Charge 5 Battery Replacement, Remove the fabric cover: passo 5, immagine 2 di 3 JBL Charge 5 Battery Replacement, Remove the fabric cover: passo 5, immagine 3 di 3
    • Use one hand to spread the edges of the fabric cover apart and your other hand to pull the speaker assembly away from the cover.
    • Remove the fabric cover.
  6. JBL Charge 5 Battery Replacement, Unfasten the battery cover: passo 6, immagine 1 di 2 JBL Charge 5 Battery Replacement, Unfasten the battery cover: passo 6, immagine 2 di 2
    • Use a Phillips screwdriver to remove the eight 10.6 mm-long screws securing the battery cover.
  7. JBL Charge 5 Battery Replacement, Remove the battery cover: passo 7, immagine 1 di 2 JBL Charge 5 Battery Replacement, Remove the battery cover: passo 7, immagine 2 di 2
    • Remove the battery cover.
  8. JBL Charge 5 Battery Replacement, Move the battery: passo 8, immagine 1 di 2 JBL Charge 5 Battery Replacement, Move the battery: passo 8, immagine 2 di 2
    • Depending on your model, the battery cable can vary in length. If your battery cable is short, be extra careful not to strain it during the following steps to avoid damaging the connector.
    • Lift the battery up and shift it out of the way to gain access to the battery connector. Don't try to completely remove it just yet—it's still connected to the device.
    • During reassembly, this is a good point to power on your device and test your repair before reinstalling the fabric cover.
  9. JBL Charge 5 Battery Replacement, Battery connector information: passo 9, immagine 1 di 3 JBL Charge 5 Battery Replacement, Battery connector information: passo 9, immagine 2 di 3 JBL Charge 5 Battery Replacement, Battery connector information: passo 9, immagine 3 di 3
    • The battery is connected to the motherboard with a power cable connector that has a small tab on the side that locks it in place.
    • To release a connector like this you need to squeeze the tab against the connector, and pull the connector straight up from its socket to disconnect the battery.
  10. JBL Charge 5 Battery Replacement, Disconnect the battery: passo 10, immagine 1 di 3 JBL Charge 5 Battery Replacement, Disconnect the battery: passo 10, immagine 2 di 3 JBL Charge 5 Battery Replacement, Disconnect the battery: passo 10, immagine 3 di 3
    • Insert a plastic spudger into the battery connector cutout.
    • Use your spudger to squeeze the tab against the connector to release it.
    • Use your free hand to grab the battery cables just above the connector and pull the connector straight up from its socket wiggling it left and right to loosen the clips securing it.
  11. JBL Charge 5 Battery Replacement, Remove the battery: passo 11, immagine 1 di 1
    • Remove the battery.
Conclusione
If possible, power on your device and test your repair before reassembly. For optimal performance, calibrate your newly installed battery after completing this guide.
Altre 5 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
140 Membri
18.085 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 105
Ultimi 30 Giorni: 570
Tutti i Tempi: 5,087
