Salta al contenuto principale
Installing a Petsafe Removable Dog Panel
Joshua Novello
Joshua Novello e 5 altri collaboratori
Ultimo aggiornamento il 22 giu 2022
40 minuti
Moderato
Introduzione
Vai al passo 1
The Petsafe Dog Panel is a removable dog door that can be installed into the frame of your sliding glass door. Before continuing to the guide, make sure the Petsafe Dog Panel contains all the provided materials and that it is not damaged in any way. Please make sure to pay attention to the warnings before screwing into the panel or your door frame through out the installation process.
Cosa ti serve
Strumenti
Mostra di più…
  1. Installing a Petsafe Removable Dog Panel, Petsafe Dog Panel: passo 1, immagine 1 di 1
    • Make sure you have all the tools necessary.
  2. Installing a Petsafe Removable Dog Panel: passo 2, immagine 1 di 1
    • Receive your PetSafe dog door in the mail.
  3. Installing a Petsafe Removable Dog Panel: passo 3, immagine 1 di 2 Installing a Petsafe Removable Dog Panel: passo 3, immagine 2 di 2
    • Measure the height of the sliding glass door frame.
  4. Installing a Petsafe Removable Dog Panel: passo 4, immagine 1 di 3 Installing a Petsafe Removable Dog Panel: passo 4, immagine 2 di 3 Installing a Petsafe Removable Dog Panel: passo 4, immagine 3 di 3
    • Remove your lock latch from the sliding door frame.
    • Lock latches may vary
  5. Installing a Petsafe Removable Dog Panel: passo 5, immagine 1 di 2 Installing a Petsafe Removable Dog Panel: passo 5, immagine 2 di 2
    • Slide the top of your dog panel into the top track of the sliding glass door.
    • Place the bottom portion of the dog panel into the bottom track of the sliding glass door.
  6. Installing a Petsafe Removable Dog Panel: passo 6, immagine 1 di 2 Installing a Petsafe Removable Dog Panel: passo 6, immagine 2 di 2
    • Measure 12” from the top, down the side of your sliding glass door frame and mark it.
    • Mark 1” above the pet flap onto the edge of your sliding glass door.
  7. Installing a Petsafe Removable Dog Panel: passo 7, immagine 1 di 3 Installing a Petsafe Removable Dog Panel: passo 7, immagine 2 di 3 Installing a Petsafe Removable Dog Panel: passo 7, immagine 3 di 3
    • With a 9/64ths drill bit, drill clearance holes into the marks made on the sliding glass door frame
    • DO NOT GO THROUGH THE DOG PANEL
  8. Installing a Petsafe Removable Dog Panel: passo 8, immagine 1 di 3 Installing a Petsafe Removable Dog Panel: passo 8, immagine 2 di 3 Installing a Petsafe Removable Dog Panel: passo 8, immagine 3 di 3
    • Fasten the panel to the interior side of the sliding glass frame with the provided ⅝” screws.
    • MAKE SURE YOU ARE DRILLING OUTSIDE OF THE RIBBED LINE ON THE DOG PANEL.
    • DO NOT OVERTIGHTEN.
  9. Installing a Petsafe Removable Dog Panel: passo 9, immagine 1 di 2 Installing a Petsafe Removable Dog Panel: passo 9, immagine 2 di 2
    • Tighten the screws with a screwdriver.
  10. Installing a Petsafe Removable Dog Panel: passo 10, immagine 1 di 3 Installing a Petsafe Removable Dog Panel: passo 10, immagine 2 di 3 Installing a Petsafe Removable Dog Panel: passo 10, immagine 3 di 3
    • Repeat steps 8 and 9 to secure the dog panel into place. Follow these steps when drilling into the clearance hole marked at the top of the frame.
  11. Installing a Petsafe Removable Dog Panel: passo 11, immagine 1 di 1
    • Slide your sliding door flush against the dog door.
Conclusione
Preparati per le riparazioni future
Acquista tutti
Joshua Novello
Membro da: 10/26/18
196 Reputazione
1 Guida realizzata
UC Davis, Team S1-G1, Bender Fall 2018 Membro di UC Davis, Team S1-G1, Bender Fall 2018
UCD-BENDER-F18S1G1
3 Membri
1 Guida realizzata
2Commenti sulla guida
My dog won’t push hard enough for the magnet to open. Is there a way to temporarily remove the magnet on either the frame or the flap?
LisaD - Replica
LisaD put a piece of masking tape over the magnet or a couple of layers of tape to make it easier to open maybe?
Robert Merry -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,443
