Installing a Metal Snap Using a Hand Press
Introduzione
Vai al passo 1Oh snap! The snap on your jacket just blew out. Fortunately, replacing it is easy. You’ll need the help of a hand press and a new snap. The hand press should be mounted firmly to a sturdy workbench—otherwise, it might slip and damage your project (or worse yet, injure you). Before you get started, make sure you check the fabric to determine whether or not it’s been damaged to the point where it cannot support a new snap. If the fabric has been damaged, you’ll need to sew a reinforcing patch onto the fabric before replacing the snap.
For replacement parts or further assistance, contact Patagonia Customer Service.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Insert the stud fitting into the upper fitting holder on the hand press.
Insert the fitting as far as it will go, so that the only visible part is the wider encasement portion of the fitting.
Tighten the screw on the side of the upper fitting holder to secure the stud fitting. Tighten the screw about a 1/4 turn past finger-tight.
Insert the socket fitting into the upper fitting holder on the hand press.
Admire your handiwork!
