Salta al contenuto principale
Infinity 3D Massage Chair (Rongtai) 3D Massage Mechanism Replacement
Timothy Allen
Timothy Allen e 2 altri collaboratori
Ultimo aggiornamento il July 8, 2024
20 minuti
Moderato
Guida fornita dalla comunità
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Infinity 3D Massage Chair (Rongtai) 3D Massage Mechanism Replacement, This guide is the second of two guides for replacement of the massage mech in a 3D chair.: passo 1, immagine 1 di 1
    • The first guide showed you how to access the mech and mech track. Now we will remove the mech from the chair.
  2. Infinity 3D Massage Chair (Rongtai) 3D Massage Mechanism Replacement, Disconnect wires from mech. This can be done at the mech itself following the color chart below.: passo 2, immagine 1 di 1
    • Another option is to cut the zip ties on the back mech cable and follow it down the the base of the chair. It can be unplugged from the connector and the mech can be removed with the back cable connected in this way. Make sure you disconnect using the white connectors show in the bottom of the image.
    • Note: If you do choose to replace the back connecting cable, please make note of the zip tie locations and when re-installing use the exact same cable routing. This will prevent the new mech from damaging the new back connecting cable.
  3. Infinity 3D Massage Chair (Rongtai) 3D Massage Mechanism Replacement, The mech will be driven out through the top of the track.: passo 3, immagine 1 di 1
    • To do this you need to remove the 4 screws and then lift the top bar out and set aside.
    How do I know which product is the best among the ones listed here? ++https://chairsbuddy.com/best-massage-cha...
    MarkWilliamson - Replica
  4. Infinity 3D Massage Chair (Rongtai) 3D Massage Mechanism Replacement, If motor is functional, you can use the chair to drive the mech up to the top.: passo 4, immagine 1 di 2 Infinity 3D Massage Chair (Rongtai) 3D Massage Mechanism Replacement, If motor is functional, you can use the chair to drive the mech up to the top.: passo 4, immagine 2 di 2
    • If motor will drive on its own you can skip steps 5 and 6 and go straight to 7.
    • To drive the mech go into a manual massage and then choose point mode. This will let you use the up and down arrows to drive the mech up to the top manually. You may need to remove the upper sensor to allow the mech to move past.
  5. Infinity 3D Massage Chair (Rongtai) 3D Massage Mechanism Replacement, Now we will  free up the walk motor so we can access the manual motor slot.: passo 5, immagine 1 di 1
    • Remove the lower screws shown in the image.
  6. Infinity 3D Massage Chair (Rongtai) 3D Massage Mechanism Replacement, Lower the walk motor into position.: passo 6, immagine 1 di 2 Infinity 3D Massage Chair (Rongtai) 3D Massage Mechanism Replacement, Lower the walk motor into position.: passo 6, immagine 2 di 2
    • Once the motor is lowered you can use a flat head screwdriver or power screwdriver to manually drive the motor up and out of the chair.
    Good trick to getting that backroller out is connect a 12v battery to the positive and negative of the motor that turns the gears. Or You can use the flathead of your drill on the backend of the motor to “manually” turn the gear but with the power of your drill.
    Chad Joseph Staffa - Replica
  7. Infinity 3D Massage Chair (Rongtai) 3D Massage Mechanism Replacement, Carefully lift mech out of chair.: passo 7, immagine 1 di 1
    • Once the motor is no longer able to move up (reached the top of the track) you can lift the mech up and out.
Conclusione
Altre 2 persone hanno completato questa guida.
1Commento della guida
Where can I find the replacement parts?
Michael Kitson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 36
Tutti i Tempi: 3,395
