Salta al contenuto principale
Infant Optics DXR-8 Power Button Replacement
Thomas
Thomas e 6 altri collaboratori
Ultimo aggiornamento il 10 gen 2025
25 - 35 minuti
Facile
Introduzione
Vai al passo 1
If your Infant Optics DXR-8 baby monitor's power button is not responding, jammed, or broken, this guide will help you to replace it. Follow the simple steps described here to safely take out the old button and replace it with a new one.
Make sure to turn off the device and unplug it from the charger before you begin.
Cosa ti serve
Strumenti
Mostra di più…
  1. Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: passo 1, immagine 1 di 3 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: passo 1, immagine 2 di 3 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: passo 1, immagine 3 di 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
    There's a layer of adhesive between the screen protector and the white plastic behind it.
    Jared Astillero - Replica
    The cover is glued on. So you’ll nee d quite a bit of force to bend it up. But then it’ll come lose glue point by glue point. At first I was afraid that I’ll break it.
    Marco Smolla - Replica
  2. Infant Optics DXR-8 Power Button Replacement: passo 2, immagine 1 di 3 Infant Optics DXR-8 Power Button Replacement: passo 2, immagine 2 di 3 Infant Optics DXR-8 Power Button Replacement: passo 2, immagine 3 di 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Power Button Replacement: passo 3, immagine 1 di 3 Infant Optics DXR-8 Power Button Replacement: passo 3, immagine 2 di 3 Infant Optics DXR-8 Power Button Replacement: passo 3, immagine 3 di 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
    Thank you so much for this - and thank you to the commenter who walked through the additional screen replacement steps! I’ve never done anything like this and I managed to replace the screen myself.
    Lauren Skinner - Replica
  4. Infant Optics DXR-8 Power Button Replacement, Power Button: passo 4, immagine 1 di 1
    • The power button is located at the top of the device.
  5. Infant Optics DXR-8 Power Button Replacement: passo 5, immagine 1 di 1
    • Remove the button by picking it up out of the hole it is connected to.
  6. Infant Optics DXR-8 Power Button Replacement: passo 6, immagine 1 di 1
    • Insert a new button by placing the small end in the hole to connect the button to the device.
Conclusione
To reassemble your device, follow the instructions in reverse order.
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
Where did you get the replacement switch?
Dave Peterson - Replica
Where can you purchase a new power switch on the circuit board for replacement?
Derrick Silvestri - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 5,210
