Salta al contenuto principale
Infant Optics DXR-8 Charging Port Replacement
Donovan Zusalim
Donovan Zusalim e 3 altri collaboratori
Ultimo aggiornamento il December 17, 2019
20 minuti
Difficile
Introduzione Migliore
Cosa ti serve
Strumenti
Mostra di più…
  1. Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: passo 1, immagine 1 di 3 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: passo 1, immagine 2 di 3 Infant Optics DXR-8 Charging Port Replacement, Internal Monitor Components: passo 1, immagine 3 di 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
    There's a layer of adhesive between the screen protector and the white plastic behind it.
    Jared Astillero - Replica
    The cover is glued on. So you’ll nee d quite a bit of force to bend it up. But then it’ll come lose glue point by glue point. At first I was afraid that I’ll break it.
    Marco Smolla - Replica
  2. Infant Optics DXR-8 Charging Port Replacement: passo 2, immagine 1 di 3 Infant Optics DXR-8 Charging Port Replacement: passo 2, immagine 2 di 3 Infant Optics DXR-8 Charging Port Replacement: passo 2, immagine 3 di 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Charging Port Replacement: passo 3, immagine 1 di 3 Infant Optics DXR-8 Charging Port Replacement: passo 3, immagine 2 di 3 Infant Optics DXR-8 Charging Port Replacement: passo 3, immagine 3 di 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
    Thank you so much for this - and thank you to the commenter who walked through the additional screen replacement steps! I’ve never done anything like this and I managed to replace the screen myself.
    Lauren Skinner - Replica
  4. Infant Optics DXR-8 Charging Port Replacement, Charging Port: passo 4, immagine 1 di 2 Infant Optics DXR-8 Charging Port Replacement, Charging Port: passo 4, immagine 2 di 2
    • Unscrew the four 3 mm screws holding the motherboard to the unit using a Phillips #00 screwdriver.
  5. Infant Optics DXR-8 Charging Port Replacement: passo 5, immagine 1 di 2 Infant Optics DXR-8 Charging Port Replacement: passo 5, immagine 2 di 2
  6. Infant Optics DXR-8 Charging Port Replacement: passo 6, immagine 1 di 1
    • Remove the old charging port and solder the new one in place.
  7. Infant Optics DXR-8 Charging Port Replacement: passo 7, immagine 1 di 1
    • Flip the unit over to ensure a correct fitment.
    Where do you buy a new charging port? Also, you didn't include new charging port as an item that is needed for this tutorial. Might be self-explanatory but why say "no parts required" when clearly a part is required?
    In any event, thanks for this tutorial. Much appreciated!
    Paul Lee - Replica
    The part you are looking for is a female Micro USB B-Type solder socket. I no longer have the unit available to confirm, but I'll bet you could contact Infant Optics and confirm with them. Sorry I can't be of more help!
    Donovan Zusalim -
Conclusione
Cal Poly, Team 13-4, Banghart Winter 2017 Membro di Cal Poly, Team 13-4, Banghart Winter 2017
CPSU-BANGHART-W17S13G4
4 Membri
4 Guide realizzate
3Commenti sulla guida
I appreciate you posting this. What kind of new charging port did you use (USB type, size, etc) and does IFIXIT sell them?
John Lynch - Replica
Donovan Zusalim -
Worth pointing out that this guide shows an older version of the DXR-8 (2014 printed on the PCB) where the microUSB port uses through-hole leads to connect to the board. Mine is a few years newer and the port was surface-mounted, which requires more skill and care to replace. I ended up ordering the part myself and taking it to a repair shop for them to do the soldering.
Danny Conrad - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 56
Tutti i Tempi: 6,579
