Salta al contenuto principale
How to create a ChromeOS Recovery USB Drive
Jacob Mehnert
Jacob Mehnert e 5 altri collaboratori
Ultimo aggiornamento il 17 set 2024
5 minuti
Molto facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
If your Chromebook's operating system ever becomes corrupted or damaged, you can recover it using Google's Recovery Utility application. This process has the tool completely remove the currently installed OS and reinstalls it onto the device.
While Chrome OS is known for being a somewhat stable operating system there are moments when you would want to have a recovery drive handy. For example, you would want to use a recovery USB in one of the following scenarios...
  • You see this error message: "Chrome OS is missing or damaged"
  • Other troubleshooting steps have no effect on the immediate issue.
Cosa ti serve
Strumenti
    • In order to make your recovery device, you will need the following items.
    • 1 x USB Drive or SD Card (8 GB is the minimum)
    • Any content that is stored on this drive will be erased during the next few steps. Be sure to back up any content you want saved, or make sure this is a drive you are going to use for future devices.
    • 1 x computer running the Google Chrome Browser, or Chrome OS.
  1. How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: passo 2, immagine 1 di 2 How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: passo 2, immagine 2 di 2
    • Open Google Chrome and navigate to the Chrome Web Store and download the Chromebook Recovery Utility extension.
    • Add the utility to Chrome and launch it. You will be greeted with this page.
    Ich möchte gern die Chrome riparian
    Ahmad Zadran - Replica
  2. How to create a ChromeOS Recovery USB Drive, Enter your Chromebook Model Number: passo 3, immagine 1 di 1
    • Click on "Get started" and you will be prompted to enter the model of your Chromebook.
    • You have the option of either entering the code that is on the device's recovery screen, or choosing from the model list.
  3. How to create a ChromeOS Recovery USB Drive, Insert your Removable Media: passo 4, immagine 1 di 1
    • Plug in your spare 8 GB USB Drive and select it from the dropdown menu.
    • Any content that is stored on the drive will be erased during the next few steps. Make sure that the drive is empty, or does not have any data that you don't want to lose.
  4. How to create a ChromeOS Recovery USB Drive, Create Recovery Image: passo 5, immagine 1 di 1
    • You will be presented with a screen that shows the drive you selected. Click on the "Create now" button and the processes will begin.
    • Do not remove the drive while the process is taking place. The process will take about 5 minutes to complete and you will be prompted when the recovery drive is finished.
Conclusione
If you intend on reusing the drive for storing files you will need to use the Recover Utility application to erase the data on the drive, and you will need to reformat it with a recovery tool.
Altre 77 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Jacob Mehnert
Membro da: 10/18/21
40.203 Reputazione
50 Guide realizzate
iFanatics Membro di iFanatics
Community
61 Membri
203 Guide realizzate
15Commenti sulla guida
Thanks only this is working all the other instructions on google didnt work… Direct and simple instructions
idide akeh - Replica
I'm glad to hear that this guide helped you out!
Jacob Mehnert -
Hello....I followed all you said here yet my USB flash drives got corrupted after the recovery utility completed
Amos - Replica
Hello, you might need to wipe the USB drive and attempt to install the recovery tool again. You might also want to check that the drive is formatted to FAT32. Other formats have been known to cause errors with the recovery tool.
Jacob Mehnert -
Does it matter if it’s a 2.0 or 3.0 USB drive???
Josh Knapp - Replica
Hey there Josh,
Ideally you would want a USB 3.0 drive especially if the device that you are attempting to recover has USB 3.0. Hope this is helpful.
Jacob Mehnert -
i dont think so, unless the usb port is usb 2.0 and you insert usb 3.0 or usb 3.1
SKIBIDI OHIO RIZZLERRRRRR -
Creates about 11 partitions on the USB? And CB311-10H isnt in the list?
nikki.k.85 - Replica
Saya ingin memulihkan Acer chromebook c733 tanpa melalui administrator sekolah, bagaimana caranya?
taufik jie - Replica
Halo, sayangnya sebagian besar sekolah akan menggunakan Google Admin, atau perangkat lunak lain untuk mengelola Chromebook mereka, jadi memulihkannya tidak akan menghalangi sekolah untuk mengelolanya. Jika Anda membeli perangkat dari sekolah, sebaiknya bicarakan dengan departemen TI sekolah Anda agar perangkat tersebut dirilis dari Google Admin.
Jacob Mehnert -
I think step 5 should be step 2
Bill Holmes - Replica
I can't find my hp elite c1030 model Jinlon os
Vuthea - Replica
Are you attempting to find it using the specific model in the model list, or are you attempting to search for the model with the model number?
Jacob Mehnert -
This info is simply WRONG ! The recovery tool requires that you are using your chromebook already. The software B4 it downloads tries to change the host hard drive. If your chromebook OS isnt working this wont help you !
Steve Wilson - Replica
Howdy there Steve, the utility tool is used through the Chrome Web Browser extension. The intent is that you use the tool to create a recover drive on a different computer than the one you are attempting to fix. Also, if you are having issues with the storage drive you are attempting to use is being detected by your computer, and is at least 8 GB.
Jacob Mehnert -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 27
Ultimi 7 Giorni: 217
Ultimi 30 Giorni: 797
Tutti i Tempi: 43,902
