Salta al contenuto principale
How to apply scratch-proof coating
Irish Jack
Irish Jack e 4 altri collaboratori
Ultimo aggiornamento il 19 apr 2024
35 minuti
Molto facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Here you can see how to make any smartphone LCD or any touch screen device scratch proof / scratch resistant using Liquid Sapphire.
  1. How to apply scratch-proof coating, How to apply scratch-proof coating: passo 1, immagine 1 di 1
    • Use Liquid Sapphire scratch proof nanotechnology coating
  2. How to apply scratch-proof coating: passo 2, immagine 1 di 1
    • Add 3 drops of Liquid Sapphire to the LCD
  3. How to apply scratch-proof coating: passo 3, immagine 1 di 1
    • With a microfibre cloth wipe up and down until the LCD surface is covered.
  4. How to apply scratch-proof coating: passo 4, immagine 1 di 1
    • keep wiping up and down until a Grey/White coat starts forming, it will look similar to a widow smear.
  5. How to apply scratch-proof coating: passo 5, immagine 1 di 1
    • Leave to dry for 10 minuets and then buff off with a shammy (Chamois) Repeat the steps 3 times in total. The device can be used immediately. Keep clear of any objects that might scratch your screen until fully cured, in 24hrs.
    • Here is a coin scratching an iphone 5 LCD, watch and see what happens.
Conclusione
Altre 30 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Irish Jack
Membro da: 08/08/13
2.452 Reputazione
1 Guida realizzata
4Commenti sulla guida
Dead product link
Jdwashere - Replica
Does this product/method work if you already have a couple of light scratches on the screen?
Thank you,
Gary
Gary Zehnpfennig - Replica
Does this product/method work if you already have a couple of light scratches on the screen.
Does this product/method work if you already have a couple of light scratches on the screen —
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 36
Tutti i Tempi: 16,703
