Salta al contenuto principale
How to Troubleshoot Generic 1A USB Car Charger
Jay R Fude
Jay R Fude e 3 altri collaboratori
Ultimo aggiornamento il February 3, 2024
15 minuti
Moderato
Introduzione
Vai al passo 1
If you have a device that will not charge in the car, then this guide is designed to help you discover if the problem is with the adapter or with the device. The guide is not difficult, but you will be working with live 12 volt and 5 volt electricity, and requires knowledge of how your multimeter works.
  1. How to Troubleshoot Generic 1A USB Car Charger, How to Troubleshoot Generic 1A USB Car Charger: passo 1, immagine 1 di 1
    • Insert the USB Micro end into the breakout, and insert the adapter into a power source, set for 12V (or automatic if in vehicle).
    • Caution: Since your device is connected to a power source, there is a low voltage current going through that could damage components.
  2. How to Troubleshoot Generic 1A USB Car Charger: passo 2, immagine 1 di 3 How to Troubleshoot Generic 1A USB Car Charger: passo 2, immagine 2 di 3 How to Troubleshoot Generic 1A USB Car Charger: passo 2, immagine 3 di 3
    • Set the multimeter to VDC, and place the leads as shown.
    • The voltage should be about 5V.
    • If the voltage is lower, check the output of the power supply. If the power supply voltage is above 6V, then we will need to continue to Step 4.
  3. How to Troubleshoot Generic 1A USB Car Charger: passo 3, immagine 1 di 3 How to Troubleshoot Generic 1A USB Car Charger: passo 3, immagine 2 di 3 How to Troubleshoot Generic 1A USB Car Charger: passo 3, immagine 3 di 3
    • Unscrew the tip to uncover the fuse.
    • Remove the fuse from the charger.
    • Make sure to document the order that everything is unscrewed. This will be important for reassembly.
  4. How to Troubleshoot Generic 1A USB Car Charger: passo 4, immagine 1 di 2 How to Troubleshoot Generic 1A USB Car Charger: passo 4, immagine 2 di 2
    • Set the multimeter to test continuity.
    • Test to know how your meter reads a closed circuit.
    • Test the fuse with the multimeter.
    • If your fuse does not allow a current to flow, you will need to replace it.
  5. How to Troubleshoot Generic 1A USB Car Charger: passo 5, immagine 1 di 2 How to Troubleshoot Generic 1A USB Car Charger: passo 5, immagine 2 di 2
    • If the fuse is allowing a current to flow, you may move on, opening the body of the charger.
    • Be aware, there may be small springs inside body.
    • Look for small breaks in the small wires. Repair of these types of problems are outside the scope of this iFixit guide, but other guides may help.
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,837
