Introduzione
Is your car having trouble starting? Is there corrosion build-up on your terminals, preventing a proper connection? This handy guide will help you remove the troublesome terminal and replace it with a brand new one.
Strumenti
Parti
Locate the terminals on the top of the car battery. Next to each terminal is a positive(+) or negative(-) sign, indicating the charge.
The positive terminal looks to be in working order, but the negative end has a lot of corrosion buildup. This terminal needs to be replaced.
Take the wire plate on top and remove it carefully from the bolt.
At this point, it is fine to handle the metal plate with your hands since the terminals are disconnected from the battery and there is nothing completing the circuit.
Remove the bottom wire plate from the bolt, placing it carefully to the side.
Altre 13 persone hanno completato questa guida.
4 Commenti
Nice post. Shop car battery at batterybhai and their expert technical team come to install the battery with all battery replacement tools kit.
very interesting post. Thanks for sharing it.
I change negative terminal to new one still have corrosion why?
