Salta al contenuto principale
How to Replace a Broken Blind Slat
Jazmine Atkins
Jazmine Atkins e un altro collaboratore
Ultimo aggiornamento il 28 mag 2020
30 minuti - 1 ora
Facile
Introduzione
Vai al passo 1
If your beautiful set of blinds has a broken slat or multiple broken slats, messing up the decorum of your house, use this guide to restore your blinds back to new. Window blinds are used to determine how much light to let in or keep out of your house all whilst adding an added barrier of protection from the outside world.
Before using this guide, determine how many replacement slats you have. Typically, each set of blinds comes with multiple unused replacements that reside near its bottom rail. Next, determine which blind slats need replacing, starting at the highest one. Step 3 will require you to start at the highest damaged slat as starting anywhere else will result in extra work for you.
Check out this video linked below that serves as a good example:
How to Replace a Blind Slat
Cosa ti serve
Ricambi
Strumenti
  1. How to Replace a Broken Blind Slat, Horizontal Blind Slat: passo 1, immagine 1 di 1
    • Using the 7/32" flathead screwdriver, gently lift up the buttons located on the bottom rail of the blinds.
    • Make sure to be careful when lifting the bottom buttons to avoid injury and button damage.
  2. How to Replace a Broken Blind Slat: passo 2, immagine 1 di 2 How to Replace a Broken Blind Slat: passo 2, immagine 2 di 2
    • Remove the bottom rail buttons to expose knots at the end of the lifting cords.
    • Untie the knots.
  3. How to Replace a Broken Blind Slat: passo 3, immagine 1 di 1
    • Start at the highest damaged slat.
    • Begin pulling the lifting cords up through the route holes of all the following blind slats.
    • If you don't start from the highest slat, it will result in you doing way more work than you have to.
  4. How to Replace a Broken Blind Slat: passo 4, immagine 1 di 2 How to Replace a Broken Blind Slat: passo 4, immagine 2 di 2
    • Again, start with the highest slat.
    • Begin removing the broken slat(s) from in between the ladder strings.
  5. How to Replace a Broken Blind Slat: passo 5, immagine 1 di 1
    • Slide in the replacement slat(s).
    • Be sure the slat(s) sits in place upon the rungs of the ladder strings.
  6. How to Replace a Broken Blind Slat: passo 6, immagine 1 di 1
    • With the new replacement slats in place, begin at the highest slat.
    • Create a loop with the lifting cords.
    • Slide the loop through each routing hole on the same side of all the slats.
    • Repeat this step on the other side, and in the middle if your blinds have three routing holes.
  7. How to Replace a Broken Blind Slat: passo 7, immagine 1 di 3 How to Replace a Broken Blind Slat: passo 7, immagine 2 di 3 How to Replace a Broken Blind Slat: passo 7, immagine 3 di 3
    • Once you reach the bottom slat, thread the lifting cords back through the bottom rail.
    • Make sure the lifting cords are even in length and the bottom rail is aligned straight horizontally.
  8. How to Replace a Broken Blind Slat: passo 8, immagine 1 di 3 How to Replace a Broken Blind Slat: passo 8, immagine 2 di 3 How to Replace a Broken Blind Slat: passo 8, immagine 3 di 3
    • Use the 7/32" flathead screwdriver to push the excess lifting cords into the bottom rail holes.
    • Slide the buttons back over the ends of the cords.
    • At each bottom rail button, double knot the lifting cords.
  9. How to Replace a Broken Blind Slat: passo 9, immagine 1 di 1
    • Plug the buttons back into the bottom rail.
  10. How to Replace a Broken Blind Slat: passo 10, immagine 1 di 2 How to Replace a Broken Blind Slat: passo 10, immagine 2 di 2
    • Lastly, gently hammer the bottom rail buttons with the handle of the 7/32" flathead screwdriver to ensure the button is securely fastened.
Conclusione
Altre 3 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
2Commenti sulla guida
Very good tutorial. Thank you.
LaReisa Cares - Replica
What happened when that string retracts and goes missing ?
Mary Nguyen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 101
Ultimi 30 Giorni: 349
Tutti i Tempi: 18,630
