Salta al contenuto principale
How to Repair a Squareplug Patch Cable with SP400 Plugs
Crystal Edwards
Crystal Edwards e 2 altri collaboratori
Ultimo aggiornamento il March 15, 2023
5 - 10 minuti
Moderato
Introduzione
Vai al passo 1
If your Squareplug SP400 patch cable isn’t producing clear audio, use this guide to resolder the broken connections.
Patch cables, even well-soldered ones, are susceptible to stress-breaks at their connections. This is usually caused by repeated plugging/unplugging with regular use. A simple resolder with fresh wire ends and solder balls should bring the cable back to life.
Before using this guide, double-check that it’s your patch cable that is faulty. It’s possible the source of the signal loss is elsewhere in the signal chain.
Cosa ti serve
Strumenti
Mostra di più…
  1. How to Repair a Squareplug Patch Cable with SP400 Plugs, Patch Cables With SP400 Plugs: passo 1, immagine 1 di 1
    • Verify that the cable is faulty (unresponsive yellow and green LED indicators).
    • Yellow LED indicator
    • Green LED indicator
    • If both the yellow and green LED indicators turn on, then the cable is not the source of any audio loss. Check the pedals, amp, guitar, or power supply for issues.
    • If the red LED turns on, then the cable is shorting and will also require a resolder.
  2. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 2, immagine 1 di 1
    • Unscrew the SP400 housing.
  3. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 3, immagine 1 di 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 3, immagine 2 di 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 3, immagine 3 di 3
    • Desolder the existing solder connections.
    • Wick the existing solder completely off of the plug connections.
    • Do not touch the plug or the wick directly while desoldering.
    • For more information on soldering, check out the How to Solder and Desolder Connections guide.
  4. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 4, immagine 1 di 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 4, immagine 2 di 2
    • Cut the ends of the cable using a pair of wire cutters to expose fresh wires.
  5. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 5, immagine 1 di 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 5, immagine 2 di 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 5, immagine 3 di 3
    • Strip the outer insulating jacket by ~1 cm.
    • The Eclipse UTP Stripper works especially well for this step.
    • Braid the ground wires.
  6. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 6, immagine 1 di 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 6, immagine 2 di 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 6, immagine 3 di 3
    • Strip the inner insulator by ~2mm.
    • Braid the signal wires.
  7. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 7, immagine 1 di 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 7, immagine 2 di 3 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 7, immagine 3 di 3
    • Tin the soldering iron tip, ground wire, signal wire, and plug connections.
    • Do not touch the plug or the solder directly while tinning.
  8. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 8, immagine 1 di 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 8, immagine 2 di 2
    • Solder the wires onto the plug connections:
    • Signal wire to the tip connection
    • Ground wire to the sleeve connection
    • The outer insulating jacket should slightly extend into the chamber of the plug to minimize cable movement.
    • Do not touch the plug directly while soldering.
  9. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 9, immagine 1 di 1
    • Screw the SP400 housing.
  10. How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 10, immagine 1 di 2 How to Repair a Squareplug Patch Cable with SP400 Plugs: passo 10, immagine 2 di 2
    • Verify that the cable is working (responsive yellow and green LED indicators).
Linea Traguardo
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 23
Tutti i Tempi: 720
