Salta al contenuto principale
How to Repair a Portable Fan
Isaac MacMillan
Isaac MacMillan e 3 altri collaboratori
Ultimo aggiornamento il March 14, 2022
10 - 20 minuti
Moderato
Introduzione
Vai al passo 1
This fix will restore your fan's original power and quiet operation. This fix does not require new parts, but does require a #1 Phillips head screwdriver, an 8mm wrench or socket, and a medium or low viscosity lubricant.
Cosa ti serve
Strumenti
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Repair a Portable Fan, How to Repair a Portable Fan: passo 1, immagine 1 di 2 How to Repair a Portable Fan, How to Repair a Portable Fan: passo 1, immagine 2 di 2
    • Unplug the power cord before beginning.
    • Loosen the 4 phillips screws around the rim and remove the front of the cage
  2. How to Repair a Portable Fan: passo 2, immagine 1 di 1
    • Remove the fan blade by loosening the screw on the shaft while pulling up.
    • The screw does not need to be fully removed before the blade will slide free.
  3. How to Repair a Portable Fan: passo 3, immagine 1 di 1
    • Remove the wiring cover located above the fan motor.
    • There are 2 more screws holding the back mounting plate and cage together. They will be removed in a later step
  4. How to Repair a Portable Fan: passo 4, immagine 1 di 1
    • Remove the motor from the mounting plate by loosing the 2 smaller screws on the front.
  5. How to Repair a Portable Fan: passo 5, immagine 1 di 1
    • Remove the final 2 screws holding the mounting plate to the cage.
  6. How to Repair a Portable Fan: passo 6, immagine 1 di 1
    • Carefully pass the motor through the opening at the back of the cage.
    How do I change the speed control switcj
    Ron Nobriga - Replica
  7. How to Repair a Portable Fan: passo 7, immagine 1 di 2 How to Repair a Portable Fan: passo 7, immagine 2 di 2
    • Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
    • The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
    • Do not over-tighten the magnet mounts during reassembly. Over-tightening may cause the motor to bind.
    The 8 mm nut is on very tight. I used an 8 mm socket (1/4” drive).
    Peter Wakamatsu - Replica
  8. How to Repair a Portable Fan: passo 8, immagine 1 di 2 How to Repair a Portable Fan: passo 8, immagine 2 di 2
    • Clean and lubricate the magnet shaft and mounting brackets
    • Any medium or low viscosity lubricant will do.
Conclusione
To reassemble your device, follow these steps in reverse order.
Altre 5 persone hanno completato questa guida.
4Commenti sulla guida
What are the chances the exact fan that I need to repair would be here? I'm about to put it back together… Let's see if it worked! 9/3/19, 10:45 pm.
Clark Nova - Replica
OK. It's back together but the fan doesn't spin. I feel the motor doing… Something. It vibrates softly. So, now to figure out why it's not spinning.
hello…my fan wouldn't work until I tilt the head upwards..what could be wrong pls???
adewale ogunbona - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 103
Tutti i Tempi: 20,093
